-   -   Reverse cable dropped. Am I screwed? (https://www.ft86club.com/forums/showthread.php?t=102079)
BFIFE22 02-25-2016 04:17 PM
So I was replacing the reverse lockout sitting in the passenger seat, and thought I had the shifter in reverse so the cable wouldn't drop, but it turns out I was in first. Is there a relatively easy way to get to the cable?
JRRIII 02-25-2016 04:21 PM
Can you see the hole in the reverse cable at all? Something similar happened to me (I don't remember if i was in reverse or not) and I was able to get a paper clip into the reverse cable hole just enough to be able pull it back up enough to get a punch through it
BFIFE22 02-25-2016 04:31 PM
Right on the money! I couldn't see any of the hole with the white/yellowish plastic pieces on the shaft, but after removing those I could see just enough of the hole to get a paper clip through. Thank you good sir!
I panicked for a second because I've heard horror stories of getting reverse cables up on other cars!
