-   Electronics | Audio | NAV | Infotainment (https://www.ft86club.com/forums/forumdisplay.php?f=27)
-   -   Toyota Axes Scion - Change Splash screen logo (https://www.ft86club.com/forums/showthread.php?t=101061)
Mikeez 02-04-2016 10:56 PM
Well, I hate scion now! Haha!
Is there a way to change the startup screen (splash screen) of the Scion FRS head unit on 2014+ model. I have the 2015 stock head unit.
Basically I just want to remove the Scion splash screen to Toyota :D
Offtop: What about the steering wheel, just overlay with a toyota badge :(?
funwheeldrive 02-04-2016 11:49 PM
Be honest, did you even try searching?
Mikeez 02-05-2016 12:19 AM
Since you ask, lol. I did, found nothing for the FRS only the brz.
KR-S 02-05-2016 12:34 AM
The thought popped into my head to try and change the splash screen too. Doesn't look like there's anything on changing the splash screen on the FR-S.
IceFyre13th 02-05-2016 04:55 PM
Plus 1 billion................
:search:
:search:
:search:
And you might of found this....... http://www.ft86club.com/forums/showt...radio+settings
go_a_way1 02-05-2016 05:02 PM
In before lock
http://ct.fra.bz/ol/fz/sw/i55/5/6/23...chy-3c5a4a.jpg
MisterSheep 02-05-2016 05:08 PM
Actually I'm kind of interested as well :D
DAEMANO 02-05-2016 05:13 PM
1. Print this...
https://tse1.mm.bing.net/th?&id=OIP....d=1.9&rs=0&p=0
2. Cut it out with scissors. Be careful with the outlines.
3. Now using your hands, tape over front of your factory Scion head unit (stereo).
4. Remove when needed.
go_a_way1 02-05-2016 05:14 PM
TDRL or w/e the hell it is/means:
YOU CANT
so get over it and if it bothers you so much buy an aftermarket unit.
/thread
MisterSheep 02-05-2016 05:15 PM
YOU CANT
/thread
http://up-ship.com/blog/wp-content/u.../01/doomed.jpg
lbroskee 02-05-2016 06:27 PM
YOU CANT
/thread
TL;DR
too long didn't read
go_a_way1 02-05-2016 06:28 PM
Originally Posted by lbroskee (Post 2537629)
TL;DR
LMAO thanks I never figured that one out and didn't want to google it. Was way more fun learning this way
Lorico 02-06-2016 06:16 PM
YOU CANT
/thread
its possible, i actually have seen a corolla with a custom screen (they obviously have the same unit) I can't remember where i found this but i copied and pasted it to my icloud, but i changed my headunit. Glad I saved it. SO here goes
Here's how to change the startup image on the entune nav:
Load a usb device, such as a flash drive with the image of your choice. The images file name, including the file extension, can be up to 32 characters. Name the image without spaces or strange characters. When saving the images to a USB, name the folder that the startup image is saved to “StartupImage” and name the folder that the screen off image is saved to “DisplayOffImage”. If these folder names are not used, the navigation system cannot download the images. (The folder names are case sensitive.)
The images file extension is JPG or JPEG. Image files of 10MB or less can be saved.
Up to 3 images can be downloaded. Plug the flash drive into your car usb port.
On the entune nav system:
Press the “SETUP” button
Touch “General” on the “Setup” screen.
Touch “Customize Startup Image”
Touch “Transfer”
Touch “Yes”
You can also delete and switch between screens.
You should now see your new startup screen flash by when the entune system is started each time.
This forum is really starting to suck with the the un helpful replies, sure i can be unhelpful too at times, but those are to people with really stupid questions.
S84kam 02-06-2016 06:27 PM
I changed my head units logo as well. But I went to the dealer and they did something similar to what lorico said.
Do you guys assume the scion symbol magically appeared when the vehicle rolled out of the production plant? Obviously someone added it there. Therefore it CAN be changed
As of late. There have been the same douche bags replying. Answering as quick as possible without the slightest bit of help. With the usual answer "have you searched yet" in hopes to receive their "thanks"
