Sent from my SM-G920P using Tapatalk |
I have it in my the Subaru XV Crosstrek. I like it. I wouldn't pay money for it even though it does everything I would expect it to. But it was standard so whatever. I still use my iPhone for GPS.
All I want is waze panel mounted. Why I'm trying to find a hack for the stock unit to do it, IDK
Thank you, I didn't realize my Subaru XV Crosstrek Hybrid Touring was indeed a Subaru XV Crosstreck Hybrid Touring and not a GT86. It is just so confusing because the GT86 has the standard double din stereo while the XV has a proprietary center console which incorporates the much larger touch screen and climate controls so you can understand how I was confused.
You're right @Luftwaffel though that was actually really easy and painless. More information in a day or two.
http://uploads.tapatalk-cdn.com/2016...3f6e74c540.jpg On a side note I have been enjoying my 4mos free trial of XM. I found my favorite station to listen to on JetBlue too.. http://uploads.tapatalk-cdn.com/2016...71055cbaac.jpg Sent from my SM-G920P using Tapatalk |
@p1l0t I live in CT also, we hv a few member live around Hartford area, we gonna meet up when it's warm out. If u hv FB then join 86ONE
http://uploads.tapatalk-cdn.com/2016...3f751b9103.jpg
So getting the little bugger out was actually pretty easy. Like @Luftwaffel and @ibroskee said just squeeze the bottom upwards of the passenger side carbon-fiber dash cover (gentle it doesn't much at all) and it will come off easily in your hand. The piece over the radio comes off easiest from right left again with just gentle pressure. The radio is held in place by 4 10mm bolts. The wires in the back are color-coded and shape specific so don't worry about what goes where too much. The little black (GPS antenna, thank you @ibroskee) wire is the shortest one so I recommend taking that one off first and putting it on last. Other than that is cake really. http://uploads.tapatalk-cdn.com/2016...4116b88a25.jpg There is one extra plug that isn't even long enough to reach the radio but is part of that same wiring setup, I'm curious what that is for. http://uploads.tapatalk-cdn.com/2016...acf3d2834d.jpg With it off you can see the real model numbers and I guess it is indeed still a Clarion in my case, not a Fujitsu-Ten (I'll update the OP later). http://uploads.tapatalk-cdn.com/2016...c55934c0c5.jpg You'll also find a QR code that comes up with the same Subaru part # http://uploads.tapatalk-cdn.com/2016...3e3203c12a.jpg And your XM radio ID, which you can find through your software so no need to take it all apart for that info but it is there. Sent from my SM-G920P using Tapatalk |
| All times are GMT -4. The time now is 08:22 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
