-   -   Spacers and adapters (https://www.ft86club.com/forums/showthread.php?t=100076)
86ING IT 01-15-2016 02:57 PM
I want to add 25mm spacers to the front and back for a more aggressive look. If later on I decide to go rocketbunny, will I be able to run 25 mm adapters along with my 25mm spacer? Anyone done this with any issues? Thanks in advance.
go_a_way1 01-15-2016 03:09 PM
https://cessnachick.files.wordpress....a-bad-time.png
get proper wheels if you go RB
/end thread
ajcarson11 01-15-2016 03:51 PM
50mm total spacer width is not a good idea. 30mm should be max -- I was fine with a 30mm spacer. You're better off with new wheels -- You are like the rest of us. You will eventually buy them... so might as well do it right! :)
8R6 01-15-2016 03:54 PM
if you're going to go up to 25mm spacer, just get a 5x114 25mm conversion adapter instead. you'll way more wheels to choose from too
NyC Zn6 01-15-2016 04:03 PM
OP don't listen to these guys sure you can
Cole 01-15-2016 04:14 PM
Jesus. Why is everyone so ok with spending thousands upon thousands for a wide body kit, but not ok shelling out the money for properly specced wheels to fit that kit?
86ING IT 01-15-2016 04:19 PM
:barf::barf:
go_a_way1 01-15-2016 04:37 PM
Or the proper suspension.... or a turbo so they make enough power to bother with wider tires
