I got the passenger door done Saturday with CLD, MLV and a Rockford Fosgate woofer. I'm a *little* bit proud of myself. Never taken apart anything on any vehicle. Not so scary now. :party0030:
https://scontent-sea1-1.xx.fbcdn.net...2a&oe=5A35BA08 https://scontent-sea1-1.xx.fbcdn.net...1c&oe=5A2BDAF5 https://scontent-sea1-1.xx.fbcdn.net...a7&oe=5A2D4A7C https://scontent-sea1-1.xx.fbcdn.net...18&oe=5A3987A0 |
CCF Sources
I'm finding closed cell foam slightly difficult to find, let alone at a good price, but I found this schtuff at walmart.com:
https://i5.walmartimages.com/asr/75f...6&odnBg=ffffff 1/8" closed cell foam for $43.20. That should work... right? Of course I don't need 300ft² though, but it's cheaper than any other place I've found, especially with the free shipping. |
Thanks for all of the great feedback everyone. I'm not on here often any more, so if you've got a question, you are probably better off posting in the thread in addition to PMing. If you PM me, I will get back to you, but it could be weeks or months.
Good luck out there, guys! |
This is some good info for when I start my project. Thanks.
Sent from my SAMSUNG-SM-N910A using Tapatalk |
Thanks for all theses pictures and the great walk-through !
I'm currently doing something similar to my gt86 and was wondering if anyone knows which component is the aluminium box near the rear speaker ? http://i.imgur.com/QlE7lyz.jpg Is it safe to have some closed cell foam close to it (touching it ?) Thanks ! |
I’m not sure what it is exactly off the top of my head but it kinda looks like something that might generate/conduct heat since it looks similar to amps/DSPs so I would personally stay away from putting any CCF on it. Sent from my iPhone using Tapatalk |
I know this is an old thread but could someone refer me to:
1)where to get these large sheets of MVL (or make and model) 2)thinsulate thickness (or make and model) used? I see offerings on ebay and amazon but there's so many brands and dimensions etc. Many thanks |
This thread was immensely helpful!
Thank you! For anyone that is sort of interested in this undertaking, I ended up doing it and it took me about two full days between installing front speakers, sub, amp (including wiring etc). I didn't want to gain too much weight so I used 1/2lb MLV from amazon https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Noico CCF (this stuff is really light) https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Amazon basics deadener https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 I also used these behind the front 6.5" speakers. I placed the amazon CLC under it and created a little platform for it to sit on. I used black silicone gasket maker to paste it on, worked great. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Getting a little roller for the CCF and CLC was also pretty useful, but not NEEDED. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 I did not deaden as thoroughly as op. I used CLC in the trunk. Both doors I used CLC, CCF and MLV. Passenger side & tranny tunnel some CLC, full MLV and CCF. Rear bench some clc, a sheet of ccf on each seat. Used ccf and MLV on tunnel on rear bench. Driver side I just used some ccf. Sound has been totally transformed and the cabin is actually a different place right now. Gained about ~40-45lbs from deadening materials. Would recommend 10/10. |
Just need to get some weight reduction mods done and the 45lbs will even out.
Sent from my SM-G998U using Tapatalk |
Did you put CCL or MLV on the rear quarter panels? I am not sure if I should fit material to the plastic panel or fill the tire well. |
| All times are GMT -4. The time now is 08:35 PM. |
User Alert System provided by
