| Maxim |
06-10-2011 04:44 AM |
Originally Posted by RRnold
(Post 46676)
Nitrogen in tires sounds like a highly debatable topic! :popcorn:
From a motorcycle perspective, tires are the most crucial piece, espeically when we're on the track. If we're running race d.o.t or slicks in either medium, soft and hard compounds, we have monitor them very closely or else we'll be sliding on our ass.
We have to check the psi @ cold tire temp and also when they are up to temp. We also have to make sure we have the correct psi per the manufacture's specs for both temps. We also have to monitor the heat cycles so most riders will use tire warmers to help keep the tire temp from fluctuating while in the pits.
I've never used nitrogen, just the regular gas air pump or compressor. Is it free and only at specific shops? Have you guys even noticed a difference?
There's some misunderstanding about the application and purpose of nitrogen in tires.
It's not a weight savings aid. The difference in weight on a low profile tire would be measured in single digit grams.
The nitrogen molecule is significantly larger than the oxygen molecule. Nitrogen filled tires generally stay at the exact same PSI for the life of the tire. I have had 4 tires filled with nitrogen on my car for over 15,000 miles, they've been through 2 winters, sat for a month and a half while I was in the field, and various other things that are bad for tires. I have not had to add any air to the tires once. The nitrogen simply doesn't leak out of the stem valve like oxygen does over time.
The tire will also deflate markedly slower if there is a leak, like a nail puncture.
There are no performance benefits to using nitrogen, however the fact that your tires will no longer slowly deflate over time, even when sitting or during extreme temperature conditions, is more than worth the $10 or so it costs to do it.
