-   Issues | Warranty | Recalls / TSB (https://www.ft86club.com/forums/forumdisplay.php?f=72)
-   -   The "Who broke it's axle" thread (https://www.ft86club.com/forums/showthread.php?t=49511)
strat61caster 06-24-2015 04:14 PM
Originally Posted by Aztec (Post 2297726)
There is no 2012 model...
Other countries don't ascribe to the North American strategy of releasing next years car many months before the year begins ('13 FRS/BRZ were available in May 2012). There are GT86's and BRZ's sold as 2012 model year cars in other countries (Europe, Asia, Australia etc.).
@shezzdog to my knowledge the axles have been unchanged from start of production.
Edit: And yes, no guaranteed solution yet, some people save money and just keep spares in the garage taken from wrecked cars or whatever.
AreteAuto 07-26-2015 11:43 PM
Originally Posted by wheelhaus (Post 2297582)
The only beneficial thing coilovers might offer over springs (and the point I believe you're trying to make) is stiffness; under extreme compression a coilover might theoretically resist bottoming a little more. This is extremely difficult to prove however, as coilovers would need to be individually measured for spring stiffness, damper settings, eye to eye, stroke, bump stop thickness/durometer, etc. IMO it's too many variables to lay a blanket statement.
Yes, that is what I was attempting to say, thank you for expounding.
stugray 07-27-2015 12:38 AM
You guys constantly freak me out.
Isnt this a little more correct?:
The only beneficial thing aftermarket coilovers might offer over OEM coilovers (and the point I believe you're trying to make) is stiffness; under extreme compression an aftermarket coilover (specifically engineered for lowering) might theoretically resist bottoming a little more.
Stock "Coilovers" ARE "Coilovers".......
Aztec 07-27-2015 02:57 AM
Unrelated to whatever the topic has gotten off to.
If people are hearing a click noise from either rear end when the drive train is engaged or disengaged it's actually just the axle nut. Replace and retorque to spec and noise is completely gone. This is a common issue with subarus
Sent from my SM-G900V using Tapatalk
wheelhaus 07-28-2015 09:01 AM
You're absolutely and especially technically correct, but the term "coilovers" in the culture IMO has always generally referred to aftermarket coilovers.
DAEMANO 01-01-2016 02:56 AM
Is there a DIY for changing these?
Found it:
http://www.ft86club.com/forums/showthread.php?t=45949
trueno86power 07-01-2016 01:58 PM
Well, guess I'm back in this club !
My left axle just begin clicking... I'll re-torque the nut and I will hope.
stevemp5 07-01-2016 02:25 PM
the car must be on the ground or in the air when I re-torque the nuts?
BlaineWasHere 07-01-2016 04:22 PM
I did it with the car in the air. I don't think it matters.
trueno86power 07-02-2016 09:29 AM
I've re-torque the axle nut over the spec (Spec 140 ft-lbs - Torque to app 160-170 ft-lbs) and it don't make any noise now. I know this will be temporary... I hope not but :cry:
trueno86power 07-19-2016 09:31 PM
Well the noise went back and the axle was really defective.
I've asked to my local dealer, they accepted to give me the part and to do it myself !
I've replaced it today and guess what, no more ticking now :)
Adam_L 07-07-2017 05:03 AM
So what is the remedy for making sure your axle doesn't break, if your only lowered 0.8 - 1" ? Is it aftermarket DU bushings ... (whiteline), or some kind of upgraded CV joint ? What should be replaced when lowering the car ?
Tcoat 07-07-2017 06:59 AM
Not much to worry about when dropped an inch or less.
Adam_L 07-07-2017 10:04 PM
Thanks Tcoat.
That's what I thought, just making sure. I was researching springs/struts about 6-8 months ago, and I boiled it down to either TRD or RCE springs. I ended up getting a set of slightly used RCE springs……just have to find the time to do the install, then roll over for a 4-wheel alignment . Ohhh, and I still need to get my camber bolts.
RFB 07-08-2017 09:58 AM
As long as you don't touch the bumper strips on the track ! -LOL -
svolo4 04-05-2019 08:38 PM
Not sure if I posted here, but I snapped my stock axle last year during a drift event. Replaced axles with DSS after that ad snapped a DSS axle today. Car is lowered and turbocharged. DSS axles were on the car for less than 1 year and haven't got a lot of abuse. I went to 2 or 3 drift events since installed them.
Stock axles survived a lot of events on NA car, but snapped after just 2 events with turbo.
Probably main reason of why DSS axle snapped is that I had some issues with boots after I installed new axles.
I'm gonna buy a new set from DSS, also going to buy PSM/PBM diff and subframe raisers. Hopefully this setup will survive longer.
chipmunk 04-06-2019 08:07 AM
Lean manufacturing & cost cutting have come a long way since the 90s or 2000s. Just because older cars withstood abuse, doesn't mean cars today should as well. Most parts are now designed for their specific purpose. Although I can't say for sure whether lowering causes increased shear in an axle, increased torque sure will.
When you mess with the geometry of the suspension, or torque output, I'm afraid you're on your own. I hate it too, but a BRZ isn't a Supra.
Hamza 01-10-2021 01:50 AM
I can't tell now whether this is a US only issue or applies elsewhere as well. I have a '13 86 and want to go lower than it already was but not sure anymore...
x808drifter 01-10-2021 03:30 AM
The cars are identical sooo.....
Hamza 01-10-2021 06:14 AM
Actually there are some differences amongst the US frs/brz and overseas 86 and on another forum some people mentioned the axle break being a US issue so that's what I'm tryna confirm. I do doubt they'd be different but fingers crossed here
