| GrimmSpeed |
02-18-2014 12:59 PM |
Originally Posted by Turkish
(Post 1536541)
First off, thanks for the quick response and the always good info. :respekt:
For a while now, I've been considering either an aftermarket snorkel like the one from HKS or buying an oem snorkel and doing my own snorkel mod. Looking at the results y'all got on the dyno for your snorkel mod, would I potentially be running too lean where my AFR peaks between 5300 and 5500 rpm? It's going to be a few years before I'm comfortable doing something like an ECUTEK tune where my warranty will be removed that is until it runs out (based on my experience with my previous BRZ, I might need that warranty), but if I can safely bump the AFR up the chart and possibly bump the other numbers up a bit that would be an easy enough mod to do. Obviously, I understand that there will still be plenty of power left on the table until I am comfortable running a tune. :cheers:
Also, I ran out of paper plates (they're about to expire) so I put my plain janes on with the GrimmSpeed reallocation kit that has been hibernating in my parts bin in my garage. I am still waiting for Travis county to get their collective asses together so I can register my custom plates. Pics with the kit on will come when I get my custom plates registered and on the car!
This is almost an impossible question to answer without actually putting the car on the dyno and checking AFR (or doing some data logging), because it's not always fair to say "1+1=2" when looking at the effects of an intake on a system. However, just for the sake of argument:
http://www.grimmspeed.com/content/im...norkel_4th.jpg
If you look at our stock vs modified snorkel runs you'll see that every run with a modified snorkel actually produced a little more power. At the same time, if you look at the AFRs, the leanest run with with the stock snorkel. So the AFRs are richer, and there is more power being made. Completely counter-intuitive. So it is possible that the TRD intake with the modified snorkel could bring the AFRs closer to stock, but without actually testing back at the dyno it will be impossible to say for sure. I wouldn't be surprised if it makes more power though.
We love pictures, so as soon as you get the new plates be sure to post up pictures of your car and the LPK!
I'm glad to help, even though I wasn't much help. At the end of the day, nothing beats time on the dyno and some tuning with a tuner you trust to make sure your car is safe and fun!
Chase
Engineering
