-   -   Long Commute? WHo has gone the furthest on 1 tank? (https://www.ft86club.com/forums/showthread.php?t=28028)
jshadeck 02-04-2013 08:21 PM
Originally Posted by ravenblackfrs (Post 711546)
ifsofacto....
ur telling me, that when i start my car and start coasting down hill, NO FUEL is being consumed to keep the car running? It runs cause the gear is engaged, and the car is rolling, but no fuel is pumping into the combustion chamber...
Thats what your saying? I suppose the electric spark could be turned off and the engine would still run too then...
If thats what you are saying, and ur right then cool, but it sounds like BS. I'm just sayin...
No fuel and no spark. Think along the lines of pop starting a car, pushing the car, pop the clutch, causing the motor to physically turn over, u then initiate spark and fuel and voila, it starts running.
If u take an engine, and hand crank it through its revolutions, it becomes a big air pump, u can turn the motor all u want by hand, and itll suck air all day, never using spark or gas.
Im not sure what other way to relate this, hopefully someone can come up w something better.
rice_classic 02-04-2013 08:29 PM
Actually, right after you start your car neither the engine nor the catalyst (in the cat converter) is at operating temperature so NO, DFCO would not come into play right after starting your car. DFCO needs everything to be at operating temp. Once your engine drops below a certain RPM (I don't know what is on the FRS but typically it's something like 1000-2000 rpms) then the injectors start firing again, even if the car is still decelerating due to how close the rev range is to idle.
And actually I'm not necessarily saying it, your OBDII computer is saying it. In some cars the ignition system does turn off too but that's not common.
Why is it that you think an engine can't spin unless it's combusting something? My mind is open, please explain.
Also, I have not confirmed that the Injection system in the Twins runs DFCO but considering it's OBDII, the chances are very likely.
Skurj 02-05-2013 07:16 AM
My yaris has this system, don't see why the frs/brz wouldn't.. so long as you don't touch gas or clutch after decelerating for 1-2 seconds it will shut off fuel or spark not sure which, mebbe both... until rpm gets around 1400 ish I believe.
Fish 02-05-2013 10:24 AM
The best I've gotten was going to Vegas then stopping in Baker in 1 tank. Was about 370.3 miles or so. According to the car I was geting about 37MPG. I think actual was about 35 though. I believe it still had a couple gallons left when I filled it too.
Dake 02-05-2013 02:41 PM
Originally Posted by rice_classic (Post 708982)
In my 6MT I can get 35+HWY but if I exceed 70mph my MPG drops back down to 30-31. I don't know if it's an aerodynamic brick wall of efficiency or the engine getting in to the torque-dip requiring more throttle input.
The thing to remember is drag increases exponentially with speed. The power needed to accelerate and hold the car from 60 to 70 is far greater than what's required from 50 to 60.
Obviously different things can ameliorate that general principle. If you can maintain 70 in traffic, you'll probably still get great mileage thanks to the drafting. But without someone clearing a path in front of you, you're better off keeping it below sixty.
