Hi I had a question... what type of lights am I suppose to order for the BRZ cluster? You said it wasn't too hard so im just trying to see as to if this is actually something that I can do by myself. I either want to change all of mine to white or to blue.
Qustion
Just out of curiousity have you made this very detailed video? I am trying to change mine I already have the pink bought and was wondering if this was made. Thanks :)
Hi I was curious as to if you could help me.. I was doing the ac part of the brz.. and for some reason some lights are working and the others aren't? Is there something I am doing wrong with the soldering? Is there a way to actually burn out the LED light it self is there an issue with having to much solder.
guys
from the previews pictures , where is the chime speaker ? |
First of all thanks for the great tutorial. I was able successfully swap my led's on my cluster gauges, but when I put everything back together I noticed that my needles don't do the sweeping motion when turning on the car. Any one know how to correct that?
I would think that it's made to not come apart for theft protection.
Door "window and lock" LED's
does anyone by chance know the type of LED that is used in the door? I was able to get everything changed over to blue but the LED's in the door are different from what is used on the console.
I did try the larger LED's but they did not work (left one original LED installed to verify if I soldered backwards. |
If this is the one you're speaking of its a T10 wedge bulb. http://farm9.staticflickr.com/8034/8...64af8578_b.jpg Sent from my iPhone using Tapatalk |
Are these correct? LED |
Thanks though. |
I did take it apart but was too nervous when I saw it was wired like an electro magnet. I also could not figure out how to remove the white plastic slider without breaking any tabs. Sadly, it's still red.
3mm round tops? Or the piranha's?
Guys does anyone know if the gauge cluster the entire assembly is replaceable. I'm asking this as I have a toyota 86 not GT , its same as scion frs.
I want to buy a spare gauge cluster just in case so I leave my original untouched. some people the gauge cluster it paired with the ECU of the car but I don't think so. What do you guys think or know about this. |
Can you point me towards a thread or guide about this. I'd be grateful :bow: |
That could be easily made with an eeprom flasher and flashing it back to the spare gauge cluster wanting to be replaced. So I need those close up pictures to locate where the eeprom chip is, what kind the eeprom chip package is soic, plcc etc. And the manufacturer of the eeprom chip also. Thanks. If It's as simple as that it's a piece of cake. |
What size are the hvac twist bulbs? t5?
Question for you all since you seem to be more knowledgable than me on the topic. I have my cluster out and taken apart, and would like to disable a few lights (TPMS, CEL, ABS, TC...). Can I just desolder and remove the LED's, or will that cause a problem? For example, on my excursion when the airbag light was burnt out, it would beep 5x repeatedly every hour.
Thanks guys |
No idea... Only one way to find out... let us know how it goes :P
So the only way to change the LED is to solder them back on is that correct?
Really want to do this, i think the frs white led look is more clean.
That would be awesome if it could be that simple, I would pay someone to do the scary part of resoldering everything
Sent from my SM-N910P using Tapatalk |
I don't mean to sound like an idiot but what type of led's do we need?:bonk: Im taking some welding/painting/ auto body classes now so my car is about to get realllllll unique:party0030:
| All times are GMT -4. The time now is 04:31 AM. |
User Alert System provided by
