also gorilla makes some inexpensive closed lugs and I hear mcgard is also really good and have great lockers. |
Thanks! |
K&N Drop-In Air Filter 3/1/16
Just got a K&N drop-in filter installed on the FR-S. Super easy install.. Just undo the clips and take out the old filter. Put in the new K&N filter and make sure the letters are facing up. Not much else to it :lol: probably the easiest install I've done.
http://www.ft86club.com/forums/pictu...ictureid=10111 |
HIC Window Visors
I purchased a set of HIC Window Visors off of ebay and got them in the mail yesterday. So, I went outside and slapped them on. They did not come with any templates nor any instructions but it seemed pretty self explanatory, take of the 3m film to expose the tape and stick it to your car. I lined it up where I wanted it on the passenger side making sure that the window did not hit it when you opened the door and then stuck it down. I then measured where I placed it so I can place it in the same exact spot next time.
Overall I like these, they're a cosmetic only item but I like the way they look especially with my vinyl wrapped roof. :D http://www.ft86club.com/forums/attac...1&d=1460757642 http://www.ft86club.com/forums/attac...1&d=1460757642 |
https://youtu.be/oVDZx5NYrcM
^ here's a quick little video a friend of mine @PMok put together. If any of you wondered what my exhaust setup sounds like, well here you go! J2 engineering catback (2.75in) with an Agency Power front pipe/ over pipe combo (2.5in). |
4/19/16 More SPC camber bolts and alignment
Yesterday I had the guys over at elite performance install some SPC camber bolts on the bottom which were paired with my already installed whiteline camber bolts up top. Gary said I could easily reach -3 degrees of camber with this setup but I had him decide what was best for my needs. He ended up trying to make the camber as squared as he could on all 4 corners. Probably next would to get some LCA's to be able to adjust camber in the rear but I am happy with the -2.4 all around.
http://www.ft86club.com/forums/attac...1&d=1461162627 http://www.ft86club.com/forums/attac...1&d=1461162627 |
Also I was looking at your build... it's kinda funny that, most of the mods you did, they all were in my build list #3... I decided to go different route and currently on built list #5 lol |
That J2 Exhaust looks Mean! http://s31.postimg.org/rhw194yxj/6f0...4244185437.png
Exterior: TRD shark fin ITEC 3rd brake light BeatSonic roof spoiler TRD/ZELE fender extension TRD Aero stabilizing cover TRD duckbill JUN side skirt ChargeSpeed rear bottom line STI front lip Chassis: TRD door stabilizer TRD strut tower bar STI V bar Cusco rear chassis brace Carbing Frame brace Interior: Diode Dynamics LED lights Toyota "86" Airbag cover TRD steer wheel TRD push start button Suspension: ARP studs Cusco LCA TRD sway bars RS-R sports-i coils Wilwood 6/4 bbk Winmax w2 brake pads Whiteline camber bolts Rays 57xtremes (F/R:18x8.5 +33) Michelin PSS (F/R:245/35-18) Engine: ...somehow that part was missing in my google sheet info |
| All times are GMT -4. The time now is 11:48 AM. |
User Alert System provided by
