-   -   Our Silver Bullet - FT-86 SpeedFactory (https://www.ft86club.com/forums/showthread.php?t=13761)
mact 03-10-2013 09:59 PM
Where in IA are the AutoX events? I want to go to some this summer.
FT-86 SpeedFactory 03-11-2013 05:30 PM
Originally Posted by swift996 (Post 785092)
Looks super clean! Are you running OEM brakes in the rear? The reason I ask is I just picked up a set of Wilwoods for the front and not sure what I'll do in the rear yet. Maybe just pads?
OEM calipers in the rear w/ Hawk HP+ pads and SS lines. Will be switching those pads out for something more aggressive soon, I believe.
Thanks!
Jeremy and I are the local directors for our SCCA autocross events. Our first scheduled event is March 24th at Adventureland Amusement Park in Altoona, IA.
Other venues we have are:
1. Iowa Events Center, Des Moines, IA
2. Oskaloosa Municipal Airport, Oskaloosa, IA
3. Iowa Speedway, Newton, IA
Hope to see you at some! We will have both cars out at all events since we are the event directors.
Cheers!
-Yo
FT-86 SpeedFactory 05-04-2013 05:42 PM
FT-86 SpeedFactory 06-28-2013 10:21 PM
Update Time!
http://ft86speedfactory.com/images/AngOnCar-4.JPG
http://ft86speedfactory.com/images/AngOnCar-5.JPG
http://ft86speedfactory.com/images/AngOnCar-6.JPG
http://ft86speedfactory.com/images/AngOnCar-7.JPG
http://ft86speedfactory.com/images/AngOnCar-8.JPG
http://ft86speedfactory.com/images/AngOnCar-9.JPG
Details:
Enkei RPF1
Offset: +38mm
Hub Bore: 73mm
Bolt Pattern: 5x100
Weight: 17.6lbs <- SUPER LIGHT!!!
Color: Black
We mounted up 265/35/18 Hankook RS3 tires in the love of keeping grip on the road.
WHY?
http://ft86speedfactory.com/images/vortechft86.jpg
Lets not forget our V2 Single Exit is now on the car.
Super lightweight. Muffler section weights in at 10 lbs exactly. Add in our mid pipe at 16lbs, entire system is 26lbs. :)
V2 SPECS:
2.5" T304 Stainless Catback to Muffler
Minimal bends, Single Piece Mid-Pipe No pie cuts and welds here.
4" Stainless Angle Cut or Rolled tips
Made in the U.S.A (Iowa to be exact.)
V-Band Clamp for rear section
Un resonated or resonated options are available on this system
Extremely light weight
Fits both manual and automatic FRS / BRZ cars
Backwards compatible with the V1 system.
Picture time.
Resonated:
http://ft86speedfactory.com/images/SingleV2.JPG
Non Resonated:
http://ft86speedfactory.com/images/V2SingleNR.JPG
Standard Pics:
http://ft86speedfactory.com/images/SingleV2-10.JPG
http://ft86speedfactory.com/images/SingleV2-11.JPG
http://ft86speedfactory.com/images/SingleV2-2.JPG
On Car:
http://ft86speedfactory.com/images/saltflatsjb.jpg
http://ft86speedfactory.com/images/SingleV2-19.JPG
http://ft86speedfactory.com/images/SingleV2-12.JPG
http://ft86speedfactory.com/images/SingleV2-13.JPG
http://ft86speedfactory.com/images/SingleV2-14.JPG
http://ft86speedfactory.com/images/SingleV2-15.JPG
http://ft86speedfactory.com/images/SingleV2-16.JPG
http://ft86speedfactory.com/images/SingleV2-17.JPG
http://ft86speedfactory.com/images/SingleV2-18.JPG
Videos contain the following exhaust mods:
Borla UEL
Motiv Over Pipe
Invidia Resonated Front Pipe
FT-86 SpeedFactory V2 Exhaust ( Single Exit )
Rev Video - Resonated Version:
[ame="http://www.youtube.com/watch?v=3x6-lBPjSjY"]FT-86 SpeedFactory V2 Exhaust - Single Exit - Scion FR-S and Subaru BRZ - YouTube[/ame]
Drive By - Resonated Version:
[ame="http://www.youtube.com/watch?v=3D9KmIF8boQ"]FT-86 SpeedFactory V2 Drive By Videos - YouTube[/ame]
More videos and dyno's after we get back from 86Expo in Las Vegas.
Drive By on the Salt Flats - Resonated Version:
[ame="http://www.youtube.com/watch?v=4BI7F4VA7n8"]FT-86 SpeedFactory V2 Exhaust Fly By - Salt Flats - YouTube[/ame]
Dipstik-sportech 06-28-2013 11:07 PM
You guys should bring the car down to BIR in September for Proving Grounds. There were some guy down there from Des Moines at the last one.
Hiros86 06-29-2013 06:10 AM
Originally Posted by FT-86 SpeedFactory (Post 911318)
are these the 17 or the special edition 18s?
FT-86 SpeedFactory 06-29-2013 10:45 AM
That photo is the 17's. Those are special order also. Pretty much any RPF1 in our fitment is special order which is why they are hard to get a hold of.
The 18's are limited edition due to the color of sticker Enkei is putting in the boxes.
FT-86 SpeedFactory 06-29-2013 10:48 AM
We're thinking about attending the September event. The June event was to close to 86Expo for us to make it.
Dipstik-sportech 06-29-2013 12:32 PM
You guys should really come down. There were quite a few of the twins down there. I plan to do the road course and drags.
FT-86 SpeedFactory 06-29-2013 11:45 PM
Well the road course is calling our name so may just have to make it happen.
FT-86 SpeedFactory 07-25-2013 02:55 PM
bump
OICU812 07-25-2013 04:56 PM
To
So you've gone to 18" Enkeis now how much heavier was overall setup compared to what you found on 17s tires and all?
Assume as well you pretty much need to be on coil overs with 18x9.5" as well to avoid any rubbing etc correct?
FT-86 SpeedFactory 07-25-2013 05:21 PM
It has been quite some time since we have been able to update any of our build threads, but we have some changes being made to the car before we head out to 86 Fest in Fontana, CA.
This update will showcase a major change :D
http://ft86speedfactory.com/images/Build-1.JPG
http://ft86speedfactory.com/images/Build-2.JPG
http://ft86speedfactory.com/images/Build-3.JPG
http://ft86speedfactory.com/images/Build-4.JPG
http://ft86speedfactory.com/images/BuildProgress-1.JPG
http://ft86speedfactory.com/images/BuildProgress-2.JPG
http://ft86speedfactory.com/images/BuildProgress-3.JPG
http://ft86speedfactory.com/images/BuildProgress-4.JPG
We are still wrapping things up on the install, but we shall be boosting soon:burnrubber:
Originally Posted by OICU812 (Post 1096233)
To
I'll have to go weigh a set here in a minute, but It's probably 4-5lbs more per corner. :)
