I’m still curious as to the additives/lubricants that are used with E85. Ethanol can be purchased by the drum :drinking: |
Tell that to grandpa
Made a few crackles and pops and keeled over. Guess we loaded the wrong tune?
ive been doing it for over a year and works for me
10% ethanol in most pump gas is the "norm" and should be fine. 85% ethanol is a different story https://fuelandfriction.com/weekend-...less-you-know/ |
So, is it safe to use e85 or do we have rubber components in our fuel system? I have 3 gas stations nearby with e85
Had my first hard start with e85 today. Temps were in the 50's and my car had sat for about 2 weeks while I was on vacation. Engine died on first start, but cranked over fine on the second try.
After that, the engine felt great on the drive. Forgot how much the combination of cooler temps and e85 really wakes the engine up. |
If you're NA, you don't need to change any fuel system components (except the flex fuel kit if you want to make sure your ECU knows the actual ethanol content). If you're FI and under 400whp, you only need larger port injectors, and a larger in-tank pump if you're aiming over 400whp. |
Have you seen one of our engines that has had ethanol run through it for 100,000 miles? I am told it's not pretty.
| All times are GMT -4. The time now is 01:27 PM. |
User Alert System provided by
