This is for about 15-20 mins at a time. I change my oil every 7-8K km and check the level every couple of weeks. My place is VERY close to the on ramp but I keep it at or below 3K rpm until the temp needle is past the second notch on the gauge. |
Ok, well I'm going to do my best not to open a different can of worms, but do make sure you're nice to the car under those conditions, especially in the colder part of the year. I've monitored my oil temp in the winter during my commute, and it took about half of my commute before the oil got close to operating temp. The coolant (and the idiot gauge needle) got there well before that, but the oil was still catching up. In the hotness of summer the stuff is nearly up to temp in the 5 minutes it takes me to reach the on-ramp. Our commute times are similar, and for me it's around 18-20 miles one-way. On these really cold days of late I've been a lot nicer to the car ever since I saw just how long it takes the oil to heat up.
Now I'm not saying "ONOZ, YOU CANT 4K NOW!", I'm just saying make sure you're not running the car too hard too early. Keep the rpms under 3k when you can until you have to hit your cruising speed. Your 4k cruise, if it's in 6th, still won't be a problem, and if anything your oil will get properly hot sooner than mine at 2400 rpms, but don't just use the coolant temp idiot gauge. Coolant gets happy a lot sooner than the oil does. |
4K at low load cruise shouldn't be a problem. It will do that for a long time before any difference in wear is evident.
In the OP's defense, I have spent more than my share of time on the 400 series highways around Toronto, and when you're not sitting still, you're doing 85-100 MPH just to keep up with traffic (particularly on the 401). If you don't, you run the risk of getting run over by an Escalade/BMW X5/6, etc that is! This car is invisible to the drivers of SUVs and crew cab dually pick-ups...just sayin'. |
Myriad |
I've cruised at/around 4K RPM on trips out of state all the time.. for hours at a time. 1/5 to 1/4 of my total car mileage is from 4K RPM "cruising".. which is about 80mph on the highway. Nothing to worry about. :thumbsup:
Also, I wonder if the whole "sounds like its working harder" is because of exhaust drone? I remember my Injen droned terribly around 3.5-4.5k RPM. |
Remember, RPM stands for Ruins People's Motors. Hahaha |
The working harder sound seems to just be resonation. This engine sounds like a lawnmower between 2500 and 3500. Drives me nuts. But at the same time it motivates me to keep the revs down unlike any other car I've ever owned where it's so smooth and quiet that it's easy to creep up to 4k for miles and not even notice. |
30k miles of 3k rpm equals a lot less engine wear than 30k mikes at 4K rpm. And no 30k miles at 1500 rpm is not even better.
Other cars have more insulation so you probably don't hear the engines or those types of tones as much. At least that's a theory. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
