Just for clarification:
No mention of any legalities regarding a 4th brake light below the factory brake lamps from my research, so you should be good with this mod, as long as your bulb fits this specification: Quote:
Any videos at night driving on road? I want to see if all 4 brake lights looks like too much..
Does anyone know if this would work in the Australian model? (FT-86)
I wouldn't mind trying it but I'm just concerned I may kill the front fog lights or "daytime" lights as they call it |
@ZILLA Love this write up. I was shocked when I picked my FR-S up that this rear reflector wasn't even used!! Very upset... couldn't wait to do this DIY. I like yours better than the other ones even went out and got the dual 194s too. Hoping I get time tomorrow to do this.
Just take the bulb back out and let the condensation evaporate out. When you put the bulb back in use a small amount of silicone on the seat of the socket and it should seal up just fine.
Chances are the socket isn't pulled tight enough to the housing to make the o-ring seal. |
Great DIY!
Love the way it turned out, especially with the blinker module. Will be doing this too, and post more pictures/videos :D Quote:
I prefer LED if possible, due to the concern for overheating. Since the blinker module is for LED only, I'm guessing you used LED and not the 194 bulbs.... ;) Thanks in advance for the info! :thumbup: |
The ones I used are here: http://www.autozone.com/autozone/acc...er=436567_0_0_ Hope that helps! |
I'll probably start working on this after xmas! :thanks: |
Hey @ZILLA
I am doing this set up and I have the exact same socket as you pictured. Am I correct in assuming that the black is live and the brown is ground? |
Did you use white or red LED's ?
Red
does it matter which one is the + and witch one is the -?
And where did you put the ground wire? |
Anyone?
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
