-   -   FA20CLUB Does it again... (https://www.ft86club.com/forums/showthread.php?t=39327)
FR-S FI 12-02-2013 07:27 PM
Yeah, great group of people and cars, had a great time!
DeBiase 12-02-2013 09:54 PM
Hey can I ask really quick you mentioned that the streetlite flywheel makes the clutch a little less smooth correct? Is this due to it being lighter and having less inertia so it changes speed a lot faster than the heavier flywheel? And also the streetlite is heavier than the prolit flywheel right? So the effects are even more noticeable on the prolite?
FA20Club.com 12-02-2013 10:17 PM
The street light is more well suited for a FI application whereas the Prolite is better for a NA or Road Racing application. Yes the weight of the flywheel does make a noticeable difference in either application I
FR-S FI 12-02-2013 10:35 PM
Because the flywheel is light, it is easy to stall the engine and will sometimes cause or contribute to chatter. I don't believe there is more than a pound or two difference between the streetlite, and the prolite flywheels, someone correct me if I'm wrong. It can be quite smooth once you get used to it...
