-   -   Vortech Visconti Tuned on BRZ Limited (https://www.ft86club.com/forums/showthread.php?t=37535)
Sportsguy83 06-05-2013 09:43 AM
Originally Posted by v1ru5 (Post 982660)
What sensor should I buy, and where do I install it? The fa20club p3 air vent gauge I bought supports a 5v input for fuel.
You need to get a gauge with a Wideband O2 sensor, examples are AEM A/F gauge, AEM failsafe, autometer A/F gauge etc.
you need to actually weld a bung in the exhaust (Overpipe is the best and most accessible place) to be able to install this wideband O2 sensor.
At least the AEM Failsafe, does include the bung, so you mark up where you would like it welded, take it to a shop, get it weld and you are ready to screw it in and connect to the gauge.
nelsmar 06-05-2013 10:12 AM
Originally Posted by Visconti (Post 982650)
You can't trust the oem sensor. It's good for a reference only.
It's suggested guys with fuel systems get a wideband AF sensor
John
Wait... aren't you tuning our forced induction based cars using this OEM sensor... If you say we can't trust it why aren't you telling us to replace them prior to sending you data logs for calibration? This is a major concern...
Visconti 06-05-2013 10:15 AM
It can only be used as a reference, everyone with a upgraded fuel system should get a aftermarket sensor.
John
2forme 06-05-2013 10:30 AM
Visconti does all his initial tunes on physical vehicles in person with a wideband.
nelsmar 06-05-2013 10:36 AM
This is a much more comforting response! Thank you!
2forme 06-05-2013 10:40 AM
I don't want you to be confused. He doesn't physically tune every customers car in person, but the tunes he provides are all based off exact tunes he has done in person. Make sense?
nelsmar 06-05-2013 11:08 AM
This i am aware of, thanks. :)
FA20Club.com 06-05-2013 08:49 PM
Originally Posted by Sportsguy83 (Post 980186)
You can get that through OBDII, so its probably going to show without needing an external sensor. @FA20Club.com can correct me if wrong :D
only pressure that can be logged on ecutek is the high pressure system you will need the external module to log what your intake pump is doing. the p3 gauge will not log either PID out of the box so you will need to gauge to at least log the primary fuel supplier to your motor which is the intank assembly
v1ru5 06-05-2013 09:16 PM
I'm still confused as to what else parts wise I will need to hook up the fuel sensor on the P3 gauge.
FA20Club.com 06-05-2013 10:50 PM
just call me tomorrow and ill walk you through that might be easier for you us
v1ru5 06-06-2013 04:15 PM
IN OTHER NEWS
I received my FastWRX Oil Pressure sending kit. Now I just need the gauge...
ichitaka05 06-06-2013 05:40 PM
Cleaned it up the off-topic & I wanna keep it that way.
Thanks
v1ru5 06-07-2013 08:56 PM
Bump with updates:
Dyno run completly stock drivetrain - pic added
Installed Rotors, Pads, Lines, transmission mount, engine mount, header, overpipe, front high flow catted pipe.
Car is getting there :party0030: :happyanim:
CBR600RR 06-10-2013 11:47 AM
what does the 3bar sensor do?:
