-   -   Hi-res pics & list of BRZ JDM model grades from stripped down base model to STI(?) (https://www.ft86club.com/forums/showthread.php?t=3601)
KevinDuMa 02-06-2012 05:57 PM
Thanks for posting that! Looks like the LED day liner is an option in japan and standard for U.S....I like
poormans_LFA 02-06-2012 06:01 PM
LED's are std. fare on the Limited for the U.S. market., not the Premium. however, seeing these LED's as an accessory brings hope that SOA might do the same for the BRZ accessories catalog here.
KevinDuMa 02-06-2012 06:14 PM
Are you sure you're not talking about the fogs? I know fogs are only on the limited but both premium and limited BRZs will have the LED strip
Premium from the Portland auto show:
http://img545.imageshack.us/img545/2586/brzk.jpg
Limited:
https://fbcdn-sphotos-a.akamaihd.net...49666774_n.jpg
McAndrewsR 02-06-2012 06:15 PM
I really hope we get the Sti options, that would seal the deal for me.
poormans_LFA 02-06-2012 06:20 PM
Limited:
fogs. this is getting weird. i guess i've spent too much time looking @ what are really JDM spec cars....because the USDM cars have the LED's in the front bumper that some JDM cars don't but have the round halogen fogs.
KevinDuMa 02-06-2012 06:25 PM
Gotcha. I'm really glad we don't have the blank opening on the premiums where the fog light is suppose to be the like jdm version
pkptd447 02-06-2012 06:27 PM
lol at the 'T' pattern on a subaru
Attachment 4583
KevinDuMa 02-06-2012 06:30 PM
Attachment 4583
lol at Subaru engine in a Toyota:D
Zaku 02-06-2012 06:35 PM
Japan cars have LED strip as a ornament sorta option, other wise it's just a FOG or No FOG option. I kinda want just fog no LED strip my self but it's not ugly to have it or anything.
WingsofWar 02-06-2012 07:23 PM
Originally Posted by poormans_LFA (Post 128303)
Wings,
It appears to be the difference of offering a "performance package" vs. a fully modified car that has actually been "breathed on" (a la BMW 3er w/ M sport pack vs. M3). However, the engines you speak of offered in STI products are performance tuned by Subaru and not STI, correct??
Exactly!
Originally Posted by lfawishes (Post 128283)
You're posting is confusing. The North American STi's are great cars, I do understand the special models you are referring too (not north american models) tend to have actually custom parts e.g. cosworth etc.. for the car and be more on the liens of a race car and are better than just a regular north american sti, unless we start getting some like s206 etc
But you also need to remember the US STi uses different differentials,axles, turbo, block, heads, intake manifold, injectors, wheels, brakes, transmission THAN THE WRX!!!!!! they are all special to the sti model.
IF you are trying to say the new impreza will get a Sti non turbo model under the wrx you are totally 100% wrong.
I did not say the North American STI isn't great. However what im talking about is this..STi did not lead the manufacturing process the specific parts used in the WRX STI (Brakes, transmission, manifold). Subaru built it, manufactured by FHI and branded it STi. STi's actual involvement should have been very small in the development of the North American models.
STi, Nismo, Mugen, RallyArt, are all Motorsports Divisions. There are boundaries and limitations these closely nit tuning shops actually do for the parent companies as a whole.
(Example;
1. If Nissan develops a high performance trim 370z, it will make more power, and likely sport different parts under the premis of Nismo 370z regardless of Nismo's actual involvement.
2. If Nissan asks Nismo to offer a performance trim 370z, it will be stock with accessories.
3. If Nismo leads the development of a Nismo 370z limited run production car, you bet your ass its going to be turbo with gobs of power and new bits.
So when you give a WRX STi.....TO STi ...they make spectacular things. Of course when STi is leading a project, it works in-conjunction with Prodrive & cosworth. Just as TRD Japan works in conjunction with Yamaha.
The current impreza is split from WRX and WRX STI.....making Impreza and WRX two completely separate models.. and if Subaru asks STi to offer a trim for the current impreza..it will not be under the premius of Impreza WRX because it being a different car. This is why if Subaru asks STi for a trim, non-turbo Impreza tS is likely, the use of the FA16DIT is not likely.
The new WRX will obviously be using a 2.0L turbo, and any STI variant will not deviate from that unless.
Again, your thoughts of the STI image is very american, or so im told.
serialk11r 02-06-2012 07:56 PM
Originally Posted by OrbitalEllipses (Post 128135)
Adds to torsional rigidity.
I apologize if I'm being stupid, but I see the pictures of the metal under the roof...
I see a piece of sheet metal bent in the shape of the roof, that will basically not resist torsion. I see 2 steel reinforcements running across it that probably will.
Can someone tell me why swapping in a fiberglass part for the metal panel on top will change anything?
serialk11r 02-06-2012 10:59 PM
Oh and @ WoW or some other Subaru experts, how different do you think the STI will be from the regular BRZ? Do you think it's likely it'll just be weight reduction, suspension/brake upgrade?
OrbitalEllipses 02-06-2012 11:06 PM
I doubt it'll come out. Maybe an air intake down the road, but I really doubt there'll be a BRZ STI or anything beyond the BRZ (tuned by) STI we've already seen. It's essentially a BRZ tS. That said, I'm still interested in the supposed Bilstein damper setup it's sporting. The UK Imprezas had the PPP (Prodrive Power Pack) that, IIRC, included the OEM Bilstein setup which from what I hear was rather nice.
aesthetect 02-06-2012 11:39 PM
the whole parts bin and sourcing debate is kind of interesting (for once) here just as this car is so focused on a parts-changing, tuner customer. Tetsuya Tada made it clear that was toyotas target and i think the RA pictured on steelies is evidence that this has crossed over to the subaru side. to me this says there will be a lot more OEM tuner parts than we have ever seen...
..maybe things like this come along?
Originally Posted by switchlanez (Post 127926)
Originally Posted by SpeedHunters
...you can lift it up with a finger but if I had to make a guess I'd say it would be far too expensive to be used on the final version of the car. It's built to very high standards and is as beautiful outside...
http://ll.speedhunters.com/u/f/eagam...I/AY0F4905.jpg
i for one would love to see a feedback from OEM engineers worked into this increased tuner focus concept, even if just through parts offerings. although i can only imagine some intellectual property or copyrights issues come along to muck it up anyway.
