For the record, I'm not advocating double clutching to shift, that's completely useless on any modern vehicle. I'm just saying that doing it will reduce wear on your synchros. |
There is absolutely zero reason to confuse the subject by talking about a useless and antiquated technique such as double clutch shifting a syncho transmission. That would be like telling the guy he better be able to heel toe shifting by the time he gets the car home. I have taught two of my teenage children to drive stick in this car. I never mention double clutching or heel toe and they both drive it just fine not knowing about such a thing. The first of my three granddaughters is next. I DID however demonstrate clutchless shifting so that they understood where proper shift points are. My wife's passat is much harder to learn stick in than the BRZ. |
Not a dig - perhaps you've forgotten how tight it was when you first started driving it? You must admit, first gear is tight as hell in this gearbox. I have nearly 7k on the ticker and I still double clutch into both second and first 100% of the time. To refer to it as an antiquated technique is doing an equal disservice to our younger drivers. I have been driving for 40 years. I learned how to drive clutchless as a kid so I know exactly what you're talking about. #sportscarlyfe |
See theres one thing that bugs me. you "double clutch" into 1st? I was always taught to never downshift to 1st except at a complete stop. So why would you need to double clutch at a stop?:iono: Quote:
At stoplights I would shut the car off & put it in first. Then start the car in gear and off you go.... Then I learned to shift a 914 which is known to have one of the sloppiest shifters known to mankind. It's all good. It comes down to drivers style. However, I am around true road racing 6 months of the year, and not once in 5 years of race driving experience has anyone ever mentioned double clutching unless the tranny/overdrive is having a problem. And that is in cars from 60s-90s and $3k to $250k |
One of the cars I learned how to drive in was a 1970 MG Midget. That car does not have a synchronized first gear, so you MUST be sitting at a complete stop to put it in first. That's why people used to be taught not to shift into first while moving, because many cars didn't have synchros on first. |
Look, knowledge and skill are always a good thing. Let's just leave it at that. |
And as for the break-in period, mine was a little stiff when I first got it, but never to the point that I had any need to double clutch to make it work. I can't help but think people are needlessly making this a lot more complicated than it needs to be. If you actually have to double clutch to get the car into a certain gear, that's probably the car's way of telling you that it shouldn't be in that gear. |
Noted in earnest. I'll report back. :cheers: |
Question, is just downshift rev-matching okay or do you have to double clutch? I usually drop from 6th to 4th or 3rd as follows: 6th -> clutch in -> shift to 3rd -> rev- match -> clutch out.
Haven't had an issue that way. I tried double clutching today (i.e. - clutch in -> neutral -> clutch out -> rev match -> clutch in) and it just seemed too cumbersome for normal commuting. |
This is my first manual, but I've also been surprised with how difficult it is to get it into first unless I'm going less than 3-4 MPH. I'm well aware what the RPM needs to be to match revs but the car just won't let me.
On a related note, as I am unaware of the mechanics behind the first gear lockout, if I'm sitting here trying to shove it into first gear, am I putting stress on something, and wearing out something I shouldn't be? In other words, is it the synchros that keep you from shifting into 1st so trying to force it in really messes with them, or is the 1st gear lockout an entirely separate mechanical process and all I'm doing is pushing a lever against a plate or something? Basically if I am indeed fighting to get it into 1st, am I causing excess wear or am I just pushing against something that won't wear out or get damaged? It's such a weird feeling, and I can hear some whirring when I'm pushing against the lock-out, so I'm wondering what is going on mechanically. |
edit: It seems I may be incorrect about the existence of a first-gear lockout. |
| All times are GMT -4. The time now is 02:49 AM. |
User Alert System provided by
