Ahhh, it sounds like you might have had more fitment issues than I did. Mine wasn't too too bad. I did consider dremeling the steering wheel a bit to add clearance before I thought about sticking the washers in there. Glad to hear you made it work though. |
Here is a pic of how the pod should be, kind of hard to see but you get it http://www.ft86club.com/forums/attac...1&d=1401834481 |
It's funny, here I am thinking I'm clever putting the washers there to make it work....nope, just have it backwards! :bonk: |
Update:
Driveshaft shop axles, and Kaaz 2 way Super Q diff installed along with the Weir Performance 4.56 final drive. Still in the process of breaking in the new gears. It's so hard not to get on the gas...especially when I am only going 58mph on the highway. The assembly of the differential went pretty smooth. As mentioned earlier, I followed @Dustin's DIY. I ended up with 0.051" of pinion shimming, and 0.237" of carrier shimming. My backlash was approximately 0.006 - 0.0088". The FSM states a required backlash of ~0.005 - 0.007". The Weir Performance instructions states a required backlash of 0.008 - 0.010". I went with a happy medium as suggested by Spence at Weir. No whining so far, so it seems as though the backlash was OK, time will tell however. I don't think I will have any problems, but will report back after break in. My final numbers while checking the torque at the pinion nut was ~32-34 in*lbs. This was in the range for all new bearings. After checking the contact, it seems the pinion could have been a bit deeper, however, I did not have the proper shims to adjust the depth. At the end of the day, I was fairly happy with the contact, especially after checking it against multiple pictures of acceptable contact patterns. FYI, the pinion nut torque values @Dustin has listed in his DIY are for USED bearings, just be aware. I was going off his values, and when everything was preloaded, I was getting numbers way higher than his, I started to worry. I then checked the FSM and found I was within the range for new bearings. So again, just an FYI. https://scontent-b-lga.xx.fbcdn.net/...50&oe=5568761D https://fbcdn-sphotos-d-a.akamaihd.n...cc0d3147aa2665 https://scontent-a-lga.xx.fbcdn.net/...38&oe=5531A03B https://fbcdn-sphotos-c-a.akamaihd.n...50953fe3b1b930 https://scontent-a-lga.xx.fbcdn.net/...68&oe=5560611F Now, installation of the diff into the car was a bit more difficult in my opinion. Ran into a few snags during. First, for whatever reason, someone did not lube the axle splines that interface with the hub on the drivers side - had to beat the axle out. The biggest issue though, was the fact that my perrin 3" cat back had issues clearing the larger MAP rear diff cover. We had to heat up the exhaust pipe and beat a good 1/4 - 1/2" radius into it as well as dremel some of the fins off the back left corner of the cover. Still, at the end of the day, it all got put together and I couldn't be happier. https://scontent-a-lga.xx.fbcdn.net/...72&oe=552B4BE9 https://fbcdn-sphotos-f-a.akamaihd.n...839273a3d454aa https://fbcdn-sphotos-d-a.akamaihd.n...5fb7cf8a98ae7b |
Sorry, haven't updated in a while. But, in short, there has been much going on with the car. I will post a more detailed update soon, but for now, here's what we have. I recently added the Ptuning water methanol kit, soon to be tuned by moto-mike. I threw on the 3.15" vortech pulley and had moto-mike tune the car, finally adding in my flex fuel kit from him. Damn, this car PULLS on E85. I cant wait to see how it does with the wmi. I also added the VIS vented hood. Love it, will post pics soon. Also plan on switching out the trunk for the VIS AMS carbon fiber trunk soon. More to come!
OH! And I am installing KW V3's today along with Vorshlag camber plates in the front, and SPL LCA's and Toe Arms in the rear. Will post pics!
are the toe arms necessary in the rear with lca's? Looks good man, although many of the pictures do not work.
Again, sorry for very little posting lately. Again, much going on with the car. Finally got the VIS Racing AMS carbon fiber trunk installed, changed the spark plugs out for the HKS super fire plugs (same heat range as stock), swapped my perrin oil cooler for the FBM version, swapped my perrin shift knob for a Raceseng one, and bought a couple 55 gallon barrels of E98 (actual E85, when you can get it, is INSANE).
In the works: Front and Rear STi Brembo swap with DBA T3 5000 series lightweight rotors (next month or so), built motor and heads from element tuning (winter), and sadly, swapping the vortech kit for FBM's stage 2 turbo kit (winter). Going for high HP/torque next spring, stay tuned! |
Update!
Pulled the engine over the holidays. Being sent out today to Element Tuning for a full build! https://scontent-lga3-1.xx.fbcdn.net...5b&oe=57494600 https://scontent-lga3-1.xx.fbcdn.net...2f&oe=57141B38 |
Woah! Was your engine going out, or did you just decide to get it built?
| All times are GMT -4. The time now is 07:24 AM. |
User Alert System provided by
