The pics don't look half bad, but how bad is it hanging over before you chopped them? |
I was a bit apprehensive about hacking up the STi kit, but then I remembered that this isn't a Ferrari, and that I'm not trying to sell it as a rare, "perfect condition" Series.Blue in two years, so screw it. It's not an irreversible change, either. The skirts can always be replaced. It looks good, though, and I don't plan on selling the car... ever. So if it loses a bit of value because I cut the ends off of the skirts, I could care less, lol. |
I believe he is saying he chopped the STI kit off because the flaps themselves sit on top of the skirt/spat, which cover the mounting points. There is no need to chop them off for installation, other than the fact that they will be raised slightly due to the side molding of the kit. I think if you have the flaps already, you would need to remove them before installing the sti kit, unless you want the flaps to be under the skirt/spats. EDIT: Now that I think about it, installing it under the skirts would be a good idea. I could potentially just lift the mounting side and slide the flaps in... I'll have to see if that'd be possible |
It fits with 0 modification. Hypebrz has it correct.
It takes a bit of effort to get all the push screws in properly. Sent from my MotoE2(4G-LTE) using Tapatalk |
That said, I don't think it'll be necessary considering the extra screws from the flaps. I'm curious if the flaps can in fact just be installed under the side molding like he said. That'll alleviate the issue with the flaps not sitting right |
So you're saying the flaps can just sit inside the side molding of the skirt/spats? is that what you did? Based on your pics it looks like you just have the flaps over the inner molding of the kit. |
Oooh, I misread. I'll check to see if they can fit under tomorrow when I change my brake pads
sweet, that'd be helpful. In for pics too if you can manage. I'm curious to see if that'd look weird since having it covered by the inner molding would be something out of the ordinary... lol! |
| All times are GMT -4. The time now is 07:23 PM. |
User Alert System provided by
