-   -   FT86Speedfactory Catted UEL Header review! (Photos and Videos) (https://www.ft86club.com/forums/showthread.php?t=60799)
husker741 03-17-2014 09:09 PM
Originally Posted by s2d4 (Post 1606953)
Ahh no, still just at low rpm. When they get on it, theres hardly any. It's just the way it is with the design, the pipe length just aren't that different from one side to the other.
You serious Clark?
[ame]http://youtu.be/Js_0UqFnCwQ[/ame]
Sypher 03-18-2014 12:53 AM
also if you want more rumble there is always the uncatted version which will definitely have more rumble. then again there is all of the other uncatted headers out there too. But this header has shown to do a good job on the torque dip.
so what works for you :iono:
s2d4 03-18-2014 03:27 AM
Originally Posted by husker741 (Post 1606969)
You serious Clark?
Yeap, absolutely. There is more rumble at low rpm and some rumble when you let off throttle. It definitely does not rumble at all times like the other UELs on the market. The difference in pulsing noises are just too close together in higher rpm for me.
s2d4 03-18-2014 03:29 AM
It's the pipe lengths itself, all they did was remove the cat so no it'll probably just get louder. Not too sure until I've heard it.
fender9530 03-18-2014 03:32 PM
Originally Posted by R6Rider (Post 1606782)
If it passes the GF/Wife test, that thing should get an award.
That depends on what your intent of purpose is. Looks like the OP wanted some performance without having a loud exhaust. I would say it fulfilled it's purpose. I don't get why people are so hung up on what it sounds like. Performance > sound (as long as it's not stupid loud).
I got exactly what I wanted from the header. I wanted to remove the torque dip without unnecessary sound. I like a little rumble but would've gone EL for the right results.
akahenry 03-18-2014 09:17 PM
Please do a drive by video. :C
ChandlerSwyng 03-18-2014 11:03 PM
So I can run this header without a tune? I just want a little power gain and finish off my exhaust sound. Don't want to void the warranty with a tune. I have the invidia catback, invidia catless resonated front pipe, and invidia overpipe.
StormTrooper 03-19-2014 01:12 AM
A header is easier to notice than a tune... Just saying.
Tuning is the modern equivalent of adjusting the points and carburetor.
ChandlerSwyng 03-19-2014 01:13 AM
Yeah I understand but this will work without one correct?
StormTrooper 03-19-2014 01:30 AM
I'm pretty sure it will but I'd wait for Speed factory to respond.
ChandlerSwyng 03-19-2014 01:31 AM
Thanks!
Simon99 03-19-2014 01:31 AM
From what I've understood all headers works without a tune, the fact that this one is catted simply means there won't be a check engine caused by the O2 sensor. But a tune is definitely a good idea if you're looking to get optimal gains out of that product.
fender9530 03-19-2014 09:17 AM
I have no tune, and it's running just fine. However, I have no way of checking AFR at this time. Would a tune help? Certainly. I had a tune on my previous Civic Si that made it 100% better, and I'll prob get one eventually for the FRS.
No CEL. Runs great. Throttle response is unchanged. I won't get into warranty though...plenty of other threads on that!
Boofneenee 03-19-2014 09:42 AM
Originally Posted by StormTrooper (Post 1603323)
From initial dynos this looks to be better in the dip.
Price i believe ofh is the lowest. Most power UEL would be the JDL. (more info may change this observation) .
You sure about that JDL having more power than the OFH? I remember seeing dynos for both. They bother hover around 190 HP on pump gas and 200 E85. I did see one JDL with like 3 more horses at 203 or something but that person had more mods.
