They can tell if the clutch is "fried", usually the plate shows signs of slipping/heat, as well as the flywheel, which will show signs of being abused or being burnt up.
Sounds to me like your clutch hydraulic line may have lost pressure. This would cause the pedal to go to the floor, and with subsequent pumping, might get you half of it back. It might be as simple as tightening a loose fitting and rebleeding the system. Did they tell you what failed on your clutch? I would think, that even with abuse, it would be pretty hard to burn up or break a clutch in 4800 miles. I would stand your ground, go higher up the food chain, and get them to replace whatever's broken. Good luck! |
Like some others have said, a loss of pressure could cause what you are describing. The Evo X has a weak clutch master cyclinder (now apparently being recalled) that when people upgraded their clutches would break the CMC.
When the CMC would break, it leaked fluid, and the clutch pedal would go to the floor and not pop back up without some assistance. |
The truth is different, though, which may be worth learning for some of the new manual transmission drivers reading here. There's abuse and then there's ABUSE! A service manager at a VW dealership related this story. A dad brings his 16-year-old teenage son into the dealership on a Friday to buy him a new GTi. The kid has never driven a manual gearbox, so someone at the dealership offers to give him a brief driving lesson to familiarize him with the basics. Dad and kid decline, and they take the new GTi home. They angrily return on Monday with a burned out clutch disk and a blued flywheel. It lasted just one weekend. Surprisingly, VW generously offered to replace the parts, but the owner had to pay for the labor. But, only this once, naturally. It is quite possible to destroy a clutch (and the flywheel via over-heating) in a mere weekend of abuse. The kid must have gone berserk, though, don't you think? :D Expensive lesson to learn. |
From the thread :$110 Track Day@Willow Springs-Big Willow- Nov 16-17 in SoCal Quote:
Makes me nervous about losing my 86 track virginity though... |
I'm not making any claims to the reason it got fried, just that it looks extremely suspicious that on his very first track day ever the clutch gets fried. Its unfortunate that it happened, but at least he's doing the right thing and paying for it out of pocket. What is unfortunate is that he took it to a dealership and now he's going to end up with another stock clutch and flywheel. He could of had a better clutch and lightened flywheel for not that much more money.
The main dealers have to do the work if you want to claim warranty. Clutch plates are not warranted against wear but they are warranted against manufacturing defects. You are entitled to Toyota HQ ruling on the cause of this premature failure and, if they refuse to warranty it you can still try to prove them wrong. You will need your own experts though. Toyota must preserve the parts and produce them to your experts or tusk an adverse finding in court should it go that far. Premature clutch plate wear is caused by inadequate pressure plate pressure. This can be due to operator error (by far the most common) defective pressure plate spring (rare but possible as these are heat treated spring steel) or hydraulics that prevent full spring pressure reaching the plate. Other possible causes of clutch failure include disintegration of clutch plate lining or failure of the pressure plate assembly. Your description is of failed hydraulics. If the clutch pedal stays fine then the master or slave cylinder failed or the clutch line blocked up internally holding the clutch partially disengaged. However, this should not wear the clutch plate unless it had been a developing fault for quite some time. What is Toyota saying are the damaged parts and why they are damaged? |
Modern engines will run at the limiter all day without breaking and you should NOT switch them off until the car has stopped. The noise can be very intimidating though so you need to stay cool. |
GG.
Time to begin practicing your heel-and-toe technique? :D If you lived near me, I'd gladly teach you. Sincerely. :) When I was done with you, you'd be beside yourself with satisfaction and joy. :eyebulge: |
They belong to you, and are not being returned to Toyota as part of the warranty process. That's awfully nice of the dealership to show you something that belongs to you :) Take pictures. Call corporate. The least you can do is ask for some kind of assistance. You might get a sympathetic ear on the other end that offers help. |
A worn clutch disc would not cause your clutch pedal to lose pressure and fall flat on the floor. Sounds like something went in the hydraulic system and they are just trying to make some money off of you.
if they aren't going to cover it under warranty get your car back and take it to a shop, you can get an even stronger clutch + install for less than that price!
| All times are GMT -4. The time now is 08:55 AM. |
User Alert System provided by
