Heck, 16" wheels will clear our BBK with the proper face design. |
For a ~2700lb car you do NOT need ~350mm rotors to slow down the car. And if you do need that much stopping power, you're better off running the right pads with proper NACA ducting to the rotors for cooling. And anyone that wants to prove me wrong: show me a FRS/BRZ with a 13" big brake kit that "needs more braking power". -alex |
FWIW, I'm not looking to add "crazy" horsepower to my car. I'm not a dyno queen or a racer. I simply want to fatten up the low-end and mid-range. The Innovative SC is perfect for my desires...I'm just waiting for the early adopters to complete the testing for the manufacturer.
So big brakes are not in my future. |
Our cars don't need anything larger than a 13" big brake kit. If you cannot accomplish what your car needs for braking with a 13" kit, you are doing something absurdly wrong. Brake systems (once properly set up piston/proportioning), really comes down to a simple physics question of how much braking power is needed for a 2700lb car. We are not driving 3500-4000lb supercars here... that's my point. If a 13" BBK can be same weight as (or even slightly less than) stock caliper/rotors, that's fine, but 14" kits often weigh more than stock, with ZERO benefits over the 13" kit other than you have to run bigger wheels. Bigger wheels have two problems: 1) more mass, and 2) more mass towards the outside of the wheel (which, all else equal, makes for worse acceleration) These are all things to keep in mind. Even if you turbocharge your car to 500HP, you do NOT need a 14" big brake kit to slow the car down unless you're running something like Bonneville Salt Flats every day. -alex Edit: My roommate keeps insisting I get 18" track wheels for the BRZ, for no reason other than "oh there's so much more fitment available"... I look at it from a simple perspective: I am not doing time attack, I don't need extra-stiff sidewall for response, I am not making more than stock HP, 17" with track tires will be more than enough for what my car makes power-wise. His only response is, 18"s have so much more fitment choices! |
For a frame of reference, look at all the properly set up track-going S13/14 240SX... the car weighs the same as ours (roughly), and the transplated SR20DET powerplant makes upwards of 400RWHP on stock internals. Big brake kits are needed at some point, but a lot of people can get away with the Z32 front/rear 4/2 piston brakes and proper cooling/pads/rotors, and not have to resort to a large brake setup to slow their cars down. The more you know... -alex |
If I'm driving down the road at 50 mph and a deer jumps in front of me, what difference does a SC make? If I'm cruising down the highway at 70 mph and I need to slow down for an exit, what difference does the SC make? What value have larger brakes brought to my 2,700 pound car? I don't care how much power you make, there is a practical and reasonable (and legal too) limit as to how fast you can drive on public roads. 50 more hp wont change my driving habits one bit. |
Gary in NJ, have you also looked at the Kosei K4R's (17x8 in +36mm offset)? Generally you want wheels with many small spokes evenly spaced out versus less spokes with more spacing between when looking for lightweight wheels as they spread the load out for better barrel and lip support. If you look at most GT race car wheels they have lots of small spokes evenly spaced out. K4R's weight about the same but less expensive than the Enkei RPF1, and have a ridiculous amount of clearance for brake upgrades in comparison.
Below is a test fit I did of the Essex Sprint brake kit template on the K4R's...look at the ridiculous amount of room available... (also notice how the spokes intersection with the lip and hub is beautifully radius'd and blended - no sharp angles to act as stress risers): http://vracer111.smugmug.com/photos/...-N5BmXmK-M.png The dark grey/anthracite color of them would look nice on a WRB BRZ too... http://vracer111.smugmug.com/photos/.../i-RPhJcXf.png |
I think the point is missed..
I'm saying: you do not need to go up to 18" wheels for a big brake kit for this car. That's all I am saying. -alex |
Thanks for the heads-up. That's a 22.4 pound savings of unsprung weight - wow. Coupled with Continental ExtremeContact DW in 225/45 which carry a zero weight penalty with the stock 215/45's, and that is a significant upgrade. |
| All times are GMT -4. The time now is 04:30 AM. |
User Alert System provided by
