Thank you so much, will try this asap
this is the cheapest one i found. or the ebay : http://www.ebay.ca/itm/Pioneer-Avic-...ht_1810wt_1163 |
Thanks! I just found the same thing just now!
"Place the 2 folders “Firmware” and “Update” along with the file “CARDINFO.cif” at G:\. (only these 2 folders + 1 file, the others in the torrent are useless at this time)"
I dont understand this step. I dont see these folders from the file that i downloaded from piratebay |
In the torrent you downloaded, you should have a zip file called "2012 upgrade.rar"
When you unzip that, it will create a folder called "z140 Files" and within that folder, you'll see the two folders and cardinfo.cif file. |
I finally got my navigation bypass completed, mostly using USB.
You can use USB to access the file navigation using testmode.key, but you must use a SD card to do the maps update, I couldn't get the update to be detected on the USB drive. To get the RenewalIFLib Replacement working with USB, you need to change lines 12 and 13 of ScriptExec.ini from: Quote:
Great info, was researching this last night on avic411.com for hours on how to do it.
This takes out some of the guess work. |
Does anyone have a copy of the NAVI.exe that needs to be edited? I checked my backup and double checked everything but I can't find the offset strings. I have the same model as indicated and supported by the hack to no avail. can't find it. anyone?
I had this problem too, but I wasn't able to find the hex string under PRG0 I found it under the PRG1 folder. I ended up finding the reason in the third AVIC411 link provided which says that the Navi file used is under the PRG1 folder if there is a USER folder that contains a PRG.FLG file. I edited the Navi.exe file from the PRG1 folder and it all works great now. |
bought the wiring harness, received it yesterday... i will probably try tonight the mute grounding bypass to unlock the DVD feature
It would be Very nice to have the ability to play movies for passengers on longer road trips.
| All times are GMT -4. The time now is 04:08 AM. |
User Alert System provided by
