| Flat Black VW |
08-23-2012 03:07 PM |
Originally Posted by sparks
(Post 397551)
VW - Were you able to adjust the guide lines?
I was able to get into the setting to adjust the guide lines, however it would not recognize the camera in the settings mode so I could adjust the lines but not see the picture from the camera, just a black screen with the lines. This made it pretty difficult to get perfect and I did not have a lot of time. I'm gonna try and mess with it more after work today, ill take some pictures when I get it right.
Also the settings menu had some other options for the camera that the short manual did not go into detail about so i'm going to have to go through the longer manual and see what it says.
Originally Posted by jpit
(Post 397792)
The BRZ sees the rear camera when the gear shift is in reverse (does not see it when just the ACC is on). The lines are going to be difficult to get rid unless they have some type of software upgrade. For those ordering cameras make sure your camera doesn't add lines also or all those lines will be distracting
Mine does come on when the car is in ACC mode. The only hang up I have right now is the camera only works if I put the car in reverse before the radio finishes booting up. As long as I do this it will continue to work until I turn the car off. If I let the radio boot up before going into reverse it will not recognize the camera at all. I believe this has to do with me getting the cameras power from the reverse lights and when the radio boots up it is not seeing the camera and locking out that option. When I hooked the camera up to a jump box it would work perfect so now I need to take the car apart again and grab power from somewhere else.
