-   Electronics | Audio | NAV | Infotainment (https://www.ft86club.com/forums/forumdisplay.php?f=27)
-   -   nalc's BRZ steering wheel audio control saga (https://www.ft86club.com/forums/showthread.php?t=39244)
Deathalo 02-17-2014 11:56 PM
Can't we just grab the steering wheel from the new WRX?
http://i.kinja-img.com/gawker-media/...b04b8fgjpg.jpg
rmjjensen 02-18-2014 10:50 AM
How much does that run from the dealer?
brianhj 02-18-2014 10:20 PM
Originally Posted by t.chk (Post 1537086)
I am planning on testing it by connecting a 9V battery to 2 pins on one side and an LED to the corresponding pins on the other to see if it lights up if it does it is proof all the pins are connected and not just some of them
Dude what? Get a multimeter and do a continuity test.
I'm gonna be looking at mine Friday when I'm off work
t.chk 02-18-2014 10:39 PM
That is just stuff I have laying around the house thatd do the job. I could buy a meter but that is 35bucks I don't have till my tax return comes in at the end of the month :D but, If you do test please let us know. It would be greatly appreciated.
brianhj 02-19-2014 04:37 AM
If I disconnect the battery and remove the fuses for the airbag am I gonna have any issues with the airbag light on my dash? My altima was a bitch about the airbag, I removed the front seat once and I could never get the damn airbag light to go away, even tried some reset procedure and it worked temporarily. I eventually had to take it in to nissan to get the damn light off.
Any issues like this?
t.chk 02-19-2014 03:32 PM
I never disconnected the actual airbag just the battery, just rested it on my seat with a box. I can't answer your question. It sounds like your Nissan though you replaced the airbag which would need to be activated at the dealer/autobody shop.
nalc 02-19-2014 04:10 PM
I've disconnected the seat airbags and reconnected them without adverse effects (I did have the battery disconnected the whole time however) but cannot speak for the steering wheel airbag.
brianhj 02-19-2014 09:15 PM
I didn't replace the airbag I just took my seats out to do sound deadening. Friday I'm just going to be checking the wiring under the airbag... good idea - I don't have to actually disconnect the airbag just get behind it. Thanks
Deathalo 02-23-2014 11:48 AM
Idk... but it looks like a great match for a BRZ
brianhj 02-28-2014 10:01 AM
The pins go all the way through. (At least two of them do, it was hard to see and hard to get my multimeter probes in there.)
They exit near the key hole (whatever) under the steering column cover. The cover comes off without taking your steering wheel off: it's actually split in two, a top half and a bottom half. There are two black screws holding it on. You have to turn your steering wheel left and right to get to them. Once those come out, pull on the steering column cover from the bottom and downwards while at the same time pressing against the hairline crack you see down the length of it. The clips should undo when you press and pull, there are about 4 of them. Cover will drop down.
The connector on the steering column looks exactly like the one under the airbag, it's white with 3 pins with wires being used.
http://s30.postimg.org/lwv0zcid9/20140228_090648.jpg
t.chk 02-28-2014 10:27 AM
Excellent news! Thanks for testing this out man.
xxscaxx 02-28-2014 01:03 PM
Thats unfortunate you could only confirm two pins passing through, because you would NEED 3 to be able to get this working through the stalk :lol:
I was messing around the other day on the way home with places to mount the buttons, and I honestly don't think theres a great spot for the buttons on our current wheel setup right now. I haven't taken the buttons and looked for a mounting location yet in my car though.
brianhj 02-28-2014 04:51 PM
I tested all 7, they're good
The second connector on the column actually has 12 pins, not sure where the other 2 go
xxscaxx 03-05-2014 08:29 AM
I'm not sure what type of pins those connectors take but I have a few lying around. Maybe I'll try to mount it up to there. Just need to figure out a location for the buttons. I still think I may hard mount it somewhere outside the steering wheel though.
tim35ct 05-07-2014 12:06 PM
thanks to NALC and Dave (the rear cam harness) guy I was able to do this. you are no longer the only radio button guy and I topped your installation with a more factory look.
tim35ct 05-07-2014 12:14 PM
heres a pic
http://www.ft86club.com/forums/pictu...478670&thumb=1
xxscaxx 05-07-2014 01:56 PM
Originally Posted by tim35ct (Post 1721133)
Man could that be any smaller? LOL
I am actually doing the same thing, but the finish is going to be awesome... :) nice job though
SilverlightPony 05-09-2014 03:39 AM
Many steps in a good direction. I'd really want these on the wheel where they're supposed to be, though.
Any word on that WRX wheel?
xxscaxx 06-12-2014 09:45 AM
Keep in mind the Wrx wheel also has the cruise control buttons on it. You would have to rewire and solder the circuit board in order to make that switch (did this on my 05 STi with an 08 STi steering wheel). If you didn't you would need to run the cc stalk from our wheel. You also would still have to pass the wires through the clock spring which would mean having to pin new wires into the factory harness on both sides (think there's enough blanks for wires for the radio controls).
It's a lot more involved..trust me lol
DrunkMonkey45 10-18-2014 05:15 PM
Did anyone ever figure out a nice place to mount the buttons?
asnatlas 05-06-2016 11:08 PM
Bump...
Julia@SimplicityInSound 09-12-2016 10:00 AM
These are a set I did with KIA steering wheel controls. Small enough to fit where I wanted, and all the buttons I wanted on the left side of the steering wheel. I molded fiberglass covers around it, wrapped in "leather" wrap, all is working wonderfully. Sometime in the near future, I plan to redo the right side of the cover and mold it around the top half a bit more.
https://scontent-iad3-1.xx.fbcdn.net...9f&oe=58DD6AB4
lbroskee 09-12-2016 02:23 PM
https://scontent.xx.fbcdn.net/t31.0-...92416869_o.jpg
curious on no tangled wires and how much u had to cut into the wheel itself
Julia@SimplicityInSound 09-12-2016 03:03 PM
No tangled wires here. I re-pinned the stock harness going into the clock spring with the KIA SWC harness. Same thing in the column... I added additional pins to the harness running out, and ran those wires to a steering wheel control module behind the radio. As for cutting, I removed about 1/4" or so from the wheel.
https://scontent-iad3-1.xx.fbcdn.net...ab&oe=58DBF086
shaynek 09-12-2016 08:22 PM
https://scontent.xx.fbcdn.net/t31.0-...15299020_o.jpg
Planning on selling? interested in buying a set
Julia@SimplicityInSound 09-12-2016 08:32 PM
The harness is pretty easy to wire up. I purchased a stock KIA harness and then swapped the plug that connects to the clock spring with the Scion plug, added pins for steering wheel wires and illumination, then added new sleeves to protect the wires. I think the harness is about $22 on ebay. It took 2 weeks to ship from Korea. I also found the controls themselves on ebay for about $20 or less even, from someone in the states. I wouldn't mind doing a write up in the future... I'll probably get around to one when I finish the new covers.
gramicci101 09-12-2016 08:35 PM
This looks so much better than the 2017 OEM buttons. Great job.
shaynek 09-12-2016 09:11 PM
please do a write up. i love the way it came out!
No1der 12-19-2016 04:48 PM
Please do write up!:bow:
Julia@SimplicityInSound 12-20-2016 10:07 PM
I will try to create a write-up in the next month... Sorry for the wait, I've been busy.
