Sent from my Q10 |
:thumbsup: Dave!
Post 1: http://www.ft86club.com/forums/showp...&postcount=113 Post 2:http://www.ft86club.com/forums/showp...&postcount=126 |
Sent from my Q10 |
Sent from my Q10 |
Well the question of pressures is also critical, and more so for track use which I have not started to monitor yet.
I think this is the first thread of its type to actually discuss anything relevant on this topic with data. There is definitely the divide as usual, what is good for the track is not so good for the street and vice versa. The question is where is that middle ground. If you are in a hot climate and track all the time 0w20 is not your oil and you should absolutely monitor oil pressures. Dave do you have data on where your pressures are at and what oil you are running. Example: (Oil temps, Ambient Temps, Coolant Temps, Intake Temps) WOT PSI, HIGH AND LOW RPM IDLE PSI CRUISING PSI |
By saying I'm not huge on quality engine oil doesn't mean I'm against using it just that I'm not very good on all the detergents and weight classes for it. Normally use what the dealer recomends. Sent from my Q10 |
http://www.upmpg.com/tech_articles/m...ity/index.html http://www.kewengineering.co.uk/Auto..._explained.htm |
Sent from my Q10 |
Sent from my Q10 |
| All times are GMT -4. The time now is 06:24 AM. |
User Alert System provided by
