This boost cut mod is working pretty well!
I modified A01E CAL ID rom file for this boost cut mod and got good result. Boost cut activated at 8 psi and deactivated at 7.5 psi. Attachment 161593 https://datazap.me/u/makinenkr/20180...zoom=2728-2758 It might need fine tuning of parameters to prevent boost fluctuation. Good job @ztan ! |
Nice work, you could likey just use the entire A01G rom in your car and get flexfuel as well |
I've applied over boost fuel cut to and tested with Kouki K00G-based OTS ROM. It works as A01E or G.
Modifications for K00G
As @AussieBRZ mentioned this is required for K00G rom, I'd like to add my modifications for K00G. Any rom definitions based on K00G could work.
But as usual use this at your own risk. Code:
<!--table name="Speed Limiting Enable (Fuel Cut)" storageaddress="10e924"/-->Code:
<table type="Switch" name="Boost Limit (Fuel Cut) enable" category="Miscellaneous - Limits" sizey="1"> |
U01A: Code:
<table name="Boost Limit (Fuel Cut) enable" storageaddress="6A9E9" /> Code:
<table name="Boost Limit (Fuel Cut) enable" storageaddress="71579" /> 4c f0 ff cb ff eb ff fb d2 <Enable>58 fe 28 d2 58 fc 28 d2 58 ff 28 d2 58 42 4b d2 58 42 0b 6c 0c Searching for those hex bytes in the file appears to return a single location in any BRZ gen1 ECU, and that first '58' in the command 'd2 58' is what the 'enable' entry modifies above. Similarly, this locates the other three addresses: 44 7a 00 00 44 7a 80 00 <Fuel Cut>43 fa 00 00 43 fa 00 00 43 f5 00 00 43 f5 00 00 <Resume>44 7a 00 00 <Active>45 89 80 00 (If you are not familiar with hex editing and can't recover from a bricked ECU, you probably shouldn't try to use this information, but if you understand what you're doing, this is perhaps hours to weeks of time saved. Cheers.) |
| All times are GMT -4. The time now is 09:06 AM. |
User Alert System provided by
