I am also skeptical of these rigid collars as well, hopefully if the CSG GP comes through, i can give my invaluable inputs. |
My car drones more than before. When it had stock suspension, the ride quality was validated by the aging grandparents while driving over cobblestones. Yes I was a **** at the time, but they asked if something happened to the car to make it more comfortable. So yes...it does work, but now my car (zero sound deadening material from the factory) drones more. FML
On top of that... the hole size needs to allow for decent alignment after a certain amount of frame damage/bending. I wouldn't be surprised if there were validation requirement for serviceable structural members. Something like "Subject 6 DUTs to 30 mph front-end collisions. Remove and reinstall the structural member 10 times. Insertion force shall be less than 20 lbs. Torque required to fully mate the component to each mounting surface shall not exceed 80% of torque specified in the service manual." I'm curious how much "serviceability" is designed into our vehicles, because Toyota has quite the reputation... and it's probably not a coincidence. "Design for Serviceability" seems like it must be someone's job there. |
Forget it... I'm just going to super glue everything on my car together!!
I can almost get my car to hit The Brown Note. How? If I accelerate hard in 3rd gear at around 3500 while playing dub on the OEM Audio + Reference. Normally I would downshift. However - if I do the above - the entire car - turbo/Perrin 3"/etc - will sync up and vibrate. I am afraid Rigicolas would send it over the edge. Good thing I took out the sound tube ages ago or else my passenger side clean-up would be astronomical. Say - I wonder if I could collect all these harmonies and run them back into the turbo for some Brown Boosts? Hmmmm.....
It's hard for a lot of us to purchase something based on "It's THAT obvious". Some people make similar statements about Megan coil-overs. While it may be outside of budget to provide any numbers; there needs to be some kind of compromise in communicating the benefits with factual statements.
^^ Not that you're wrong, but better feel might give you the confidence to push harder on a more consistent basis, which will make you faster in the end.
| All times are GMT -4. The time now is 07:56 AM. |
User Alert System provided by
