Originally Posted by ill86
(Post 269818)
Yep, HKS certainly doesn't know what they're doing. What are they lacking in design? Atleast they aren't putting the element in a hot engine bay. It works. Doesn't need to be a ground breaking reinvention of the air cleaner assy...
So, what would you do differently when designing your intake? My reply was to suggest constructive criticism instead of knocking a premier Japan tuning house.
" The HKS Premium Line of Suction kits are for those who want maximum performance out of their intake system, but do not want to change any of the intake characteristics. This particular kit keeps the factory air box, replaces the factory air filter with a high flow foam filter, and replaces the factory plastic intake pipe with a hard pipe."
^ Their intent was to keep it simple. They suceeded.. :)
Oh, where to begin, my post definitely did not say that HKS does not know what they are doing.
Quite the opposite, they literally took less than an hour designing the intake for this car, using the stock MAF housing and filter box ensures them that the A/F will be unaffected and keep their cost extremely low.
Replace the stock filter element with a fallapartincoupleofmonthsfoam element, slap on an HKS sticker put it in a pink/purple box and tell you this the the "maximum performance" out of an intake system, but it is HKS so you will pay a premium, bend over and smile at the same time. They definitely know what they are doing!
First of all let's clear something up very quick, their intake is a replacement PIPE for the stock "System", it is not an "Intake System". (needed to get that off my chest")
Every consumer should ask EVERY manufacturer for R&D data, (good manufacturers will provide this data without you even asking for it) just like people demand dyno charts with A/F graphs from every other company, HKS should do the same. Let's see their R&D data, if they do not provide one then no proper R&D was done for this particular item.
On the other hand HKS does make some really nice products, we have been and continue to use them.
As far as what we would do differently, well, wait a couple of weeks once we have actually finished our R&D we will make a nice post with all the pictures, videos, dyno, A/F charts etc. :D
Originally Posted by Laika
(Post 269866)
From what I can tell...
That's the equivalent of saying an FRS priced at $40k is worth your respect and support because Scion reached their goal of making a simple car. The stock piping probably does the job 95% the same as the HKS job here and it saves you $400....?
No, you are wrong! We are talking about the HKS "Intake System",
you pay your US$ for my JDM parts! NOW!!! :popcorn:
(Post 269940)
What?! Lol
No body is forcing HKS intakes on anyone. If it's too much $, don't buy it. My initial reply was to ask what R&D was missed in their successful attempt at making a replacement pipe and conical filter inside the oem box.
In other words. They have created a simple "intake" replacement.
Any my initial post was what R&D was actually performed to create this "simple" "intake system" that demands $$$$
Originally Posted by Jason@Nameless
(Post 270188)
? How do they put the filter inside the airbox while simultaneously using that billet MAF housing? They'd have to plug the OE MAF boss on the filter box. As far as I can tell that's just a short ram straight off the front of the motor. Similar to the design we've prototyped but we're running a shroud to the factory inlet as well. And no turbokillerdeathshroom filter. HKS makes some great products. Their intakes have never been known for being great. They're car jewelry.
As for the questions about an air horn vs. a filter on a stick, most decent conical filters on the market have the air horn feature built into the outlet flange on the filter.
J
See below.
Originally Posted by Pscylo
(Post 270219)
Was just going off of what was shown as well as parts in the kit. I did see the exact same kit on another site with a drop in filter instead of the shroom, but looked to be that same sponge filter material...
I believe that there is confusion as to what exactly is available from HKS is it a short ram style intake or a replacement pipe with a drop in filter element.
