wait so what does it mean for newbies, like me, if I want to shift smoothly again? Shift, gas a little then release the clutch slower?
no it means that you effectively can't drop the clutch, even if YOU do, the car limits the speed at which the fluid flows back and therefor the shock to the system is reduced.
it means if you are a newb to clutch it won't matter because this is what you will get used to, don't even think about it just learn to drive by doing what feels smoothest |
Glad Im reading this because I thought I was going crazy not being able to figure out how to shift smooth 1-2. All my life I've driven manual cars never had an automatic actually but I feel like I don't know how to drive sometimes with this clutch delay valve thing. Weird I guess I just have to get use to it. I don't like the feeling it gives very much.
Yes, this drives me absolutely insane. If anyone manages to remove/disable theirs please post up specifics on what you did and results!
I'm glad I saw this too, 1st to 2nd annoyed the crap out of me when I first bought the car. I've been driving stick since I started driving, it made me start thinking to myself, damn I suck at clutch work now. I've gotten mostly used to it now. Still get on the gas a little too soon every once in awhile though. Bugged my Mom too, and she has driven stick since she started driving.
Adjusting the point of engagement lower also helps to minimize this.
http://www.ft86club.com/forums/showthread.php?t=8040 |
Some posters here should not be wearing combat boots when driving their manual transmission BRZ.
Try using bare feet (with or w/o socks) for a while and practice to get a better feel of engine rev and clutch actuation. Try to keep your left heel on the floor and use it as a pivot point (and not hip and knee pivoting) The BRZ is not a truck. |
Serious question (I know nothing about clutch-delay valves)-- if there's a delay valve, how can we get wheel chirp going from first to second if we powershift? Is the valve just not effective enough to completely neuter a clutch dump? If so, what's the point of having it since it sounds like it would only make a very minor difference in terms of absorbing shocks?
The thing that kind of annoys me most about the stock drivetrain is the way you get a "bouncing" feeling from the tranny when getting hard on the throttle even after the clutch is fully engaged, which I assume is just an effect of the soft motor mounts and that big rubber donut where the diff meets the rear subframe. |
Get a pair of Converse All-Stars as driving shoes. Flat, thin sole canvas shoes which allow you to really get a good feel of the pedals. |
I'm not sure if this is the reason, but it's my bet: Drive-by-wire might be an issue - it seems old-school "cable throttle" cars seem to be easier to drive smoothly.
It took me awhile after transitioning from an older M/T car, but eventually you get the "hang" of it |
I'm not concerned about this CDV. I wasn't concerned about the one in my S2K either. It's very easy to learn to live with it.
No offense to anyone in here but a good set of shoes doesn't solve the issue here. The issue is when shifting quickly, especially 1st to 2nd, you have to delay how quickly you get back on the accelerator, otherwise your clutch will not be fully engaged yet even though the pedal is fully released. Yes this is easy to avoid but it's not a behavior that is constructive towards spirited driving or track use.
| All times are GMT -4. The time now is 06:25 PM. |
User Alert System provided by
