-   Tracking / Autocross / HPDE / Drifting (https://www.ft86club.com/forums/forumdisplay.php?f=39)
-   -   Custom tunes safe for track usage? (https://www.ft86club.com/forums/showthread.php?t=75856)
glamcem 10-15-2014 04:41 PM
but again, that doesn't mean things cannot go wrong.. you just have to decide if it's worth to take risks with modding these cars, in my case I cannot imagine driving these cars in stock form, meet me sometime at Redmond and we'll find a place that you can test drive my car and can grab a coffee afterwords, that may change your judgment ..maybe extra power is overrated or maybe the opposite :)
glamcem 10-15-2014 04:43 PM
Originally Posted by ddeflyer (Post 1985326)
Speaking of catch cans, I was surprised that, on the stock engine setup (as in nothing changed), I got a small (but very noticable) boost in power when I added catch cans (kind of like adding some race fuel). In about 30 track days since then I've only emptied the catch cans once and even then there wasn't very much in them. Such a minuscule amount of oil can make such a large difference!
well I am also surprised the fact that you were able to notice the difference, where do you guys take your butt for a dyno calibration? obviously, I sure need one :D
ddeflyer 10-15-2014 04:52 PM
Originally Posted by glamcem (Post 1985319)
@Sleepless, I think you're overly concerned with the basic bolt ons and tune, if you think about it, it's nowhere near close to the complexity of the FI and tune since there are a lot more parameters and things that can go wrong ,, I think the list from more complex to simple would be something like this Turbo>Supercharger>bolt ons>stock .. then again there are some cases where the OEM tune was the problem (there are many TSBs about the factory reflashes) and people had custom tunes because of that ..
I bet there are hundreds of bolt on + tuned cars on the road and track, in fact I hardly ever see a bone stock FRS/BRZ :) with that said, there are always risks associated with taking these cars to the track ..if the car was not that boring in stock form we wouldn't bother modding them :/
I've been "heavily track testing" my car with KW kit and guess what at the very same tracks you attend to (temps, octane, elevation) but I never had any tune related issues so far, what more evidence you need? :)
While you might not be having any issues, you are only one data point. For all that any of us know you might have a particularly solid engine or have some driving characteristic that avoids a critical issue everyone else might have. If you think about it, the stock characteristics were designed with intimate knowledge of the behavior of these engines under a wide array of conditions throughout the simulated lifespan of the engine. Your tune might be great for your particular setup today, but it might cause an issue with every 20th car or some such when put to heavy use conditions. In five years your tune might also cause other premature failures.
I guess what I am saying is that one person's experience doesn't prove safety and claiming otherwise is dangerous (especially since someone is likely to look past issues on the setup that they have worked hard to construct).
glamcem 10-15-2014 04:58 PM
certainly, and I mentioned that in my post (#15) ..
regarding to the OEM tunes, I think we all agree that in stock form these cars were designed to last and pass emissions (both not related to track use), not to perform so it is not hard to understand that a car in Arizona deserts and Boston winter have the same exact tune, ever heard about factory reflashes that occurred after catastrophic failures?
ddeflyer 10-15-2014 09:21 PM
Yeah, I think we wrote posts while the other was posting :)
I just get punchy when someone says (or implies) something worked for them so its good for everyone.
And yes, I agree that the stock tune HAS to make sacrifices, some of them might even be detrimental to the cars life. I just worry that alot (probably most) tuners aren't going to have a real comprehension on what alot of those trade offs are. I base that mostly on the kinds of crazy things I seen on street only cars sometimes.
Sleepless 10-28-2014 11:46 AM
Originally Posted by dradernh (Post 1984894)
From page 3 of Jackson Racing's Installation Instructions:
When at the track, we REQUIRE running a minimum of 50% 100 Octane fuel. We highly recommend running 75-100% 100 Octane when at the track.
And, in response to a related email inquiry of mine:
We recommend customers with access to only 91/93 octane at the track to put a full tank of 100 octane in, and then top off with the 91/93 every couple sessions. As stated in our instructions, it is also important to keep above half a tank due to fuel starvation.
Note that the JR tune is a 91 octane tune (i.e., that's the minimum octane that can be run when using the tune).
That is VERY useful info which I was not aware of, and, pretty much at the heart of my "concerns". It also means that an SC is out of the question for me since only one out of the four tracks in the NW has race gas.
dradernh 10-28-2014 12:01 PM
Agreed. That throws an entirely different light on the notion of running that SC at the track. And quite possibly, any FI.
If I were to go FI, I'd get the MoTeC plug-in ECU replacement and then get a qualified MoTeC tuner to tune it. By the time all was said and done (FI, install, ECU, dyno tune, final tune at the track, and whatever etceteras came up along the way), it would likely be north of $12.5K.
OkieSnuffBox 10-28-2014 01:07 PM
Is there timing or VVT maps that could be changed to reduce power/heat levels on track that would make 91/93 oct maps safe to use?
My local track sells race gas, but sometimes they have it, sometimes they don't. Sometimes they don't even have 91.
It would be a huge, HUGE PITA to get ready for a track day, drive out, setup, etc only to find, "Nope, don't get to run today because we are out of race gas."
CSG Mike 10-28-2014 02:54 PM
It would mean tracking is out, period, for you.
The car is already unhappy on 91/92 octane from the factory. What race gas does for you is buy you headroom in case you overheat or get a hot spot in your cylinder; 100 octane has anti-knock additives and is more knock resistant in general, as well as having a lower flame front speed. Pump/Street gas, on the other hand, is made to keep your engine clean and be as cheap as possible while maintaining the octane rating.
While we don't run pure 100 octane, we do put in a few gallons per tank when tracking, as the car is noticeably faster and smoother. You can have VP100/101 5 gallon containers shipped to your home, and it will easily fit in the back seat of your car. It's approximately the same size as a 5gal water bottle, and comes fully sealed.
Most guys that track already put in a gallon or two of 100 as a precaution anyways, and most people transport their own high octane or E85.
dradernh 10-28-2014 05:45 PM
Is that a twin-specific thing, or do track day drivers of different makes generally do that in Southern California?
The first person I've ever come across doing this here in the Northeast was a twin owner last month at Watkins Glen. He was having what he thought might be tune issues, and he thought that adding a few gallons of 100 unleaded would add a margin of safety.
In my mind, something is wrong if a 91 octane or whatever tune isn't usable or safe at the track, but becomes so if higher octane fuel is added. It's as though in reality you have a 95 octane or a 97 octane tune if you're going to lean on the car. New one on me.
ddeflyer 10-28-2014 06:00 PM
I think there are a couple of important things to take note of. First and foremost, we are running engines with a 12.5:1 compression ratio which are intended in stock form to be using 93 octane gas. Even on the stock tune you get a substantial feeling boost from adding a little 100 octane fuel (street or track).
Beyond that, driving on track is a brutal experience for an engine. Temperatures skyrocket with so much time spent at high RPM and WOT (wide open throttle). For the FA20 engine, if you don't have an oil cooler then temperatures can hit 285F pretty easily. That extra heat can increase the amount of knock that the engine will see.
What I am getting at is that, in stock form, these engines are likely more prone detonation related issues, but other engines are still likely to benefit from higher octane gas when on track.
CSG Mike 10-28-2014 06:54 PM
It's a twin specific thing; we have REALLY REALLY high compression for a gasoline engine.
The only other car I know of this high is a 458 Italia, and I'm willing to bet a 458 owner isn't going to track on 91 octane ;)
Add forced induction into the mix, and you really should be running 100 octane.
Sleepless 10-28-2014 07:13 PM
12.5:1 is not a big deal for a direct injection engine. I have not problem running 91 at the track. I tried a tank with 50/50 mix of 91 and 100 and found no performance advantage.
Sleepless 10-28-2014 07:23 PM
The manual says 93 is preferable but 91 can be used with no detrimental effect on durability or drivability.
The only cars that I have used higher octane fuel in are turbos, and only on hot days to minimize power loss due to the ECU backing off.
