-   DIY (Do-It-Yourself) Guides (https://www.ft86club.com/forums/forumdisplay.php?f=43)
-   -   Vented BRZ Fender Trim! (https://www.ft86club.com/forums/showthread.php?t=70815)
midnight23 07-28-2014 06:30 AM
Originally Posted by B-R-Z (Post 1868083)
I hope someone makes\sells these one day. The stock fender trim is so cheesy looking. I might try to buy a set of these to try this on instead of potentially ruining the originals in my fenders.
I don't care so much to vent my engine bay, but I'd like to have actual vents in the fender trim instead of solid plastic. Kia Optima: 1 Subaru BRZ: 0 in this department.
it's a pretty penny but prova makes something like this.
MemphisR 07-29-2014 02:50 PM
Is there any scratching on the paint due to the mesh sitting up against the fender or is there still a bit of room between the mesh and the fender?
Gunman 07-29-2014 07:20 PM
Originally Posted by BadBRZ (Post 1866164)
I like, buuuuut .. Unless the area around the vent is a low pressure zone, nothing will bent out of that area...
Could add some ducting, and use them to vent the front wheelhouses, and gain some downforce :)
troek 07-30-2014 05:14 AM
Does the hood seal that area off when its closed? Seems like it might
steve99 07-30-2014 06:16 AM
Mob called PROVA make vented fender trims for brz/86 google prova brz vent , not cheap though
steve99 07-30-2014 06:19 AM
easy cheap venting for engine bay , unclip the black plastic piece at rear of underside of bonett on drivers side , for me anyway
troek 07-30-2014 06:25 PM
hmm ill have to look into that for track days in the heat.
Target70 07-30-2014 07:23 PM
I want to do this and use an air speed meter, that you can find on amazon for as little as $15:
http://ecx.images-amazon.com/images/I/41OZNfgXvrL.jpg
to see how much venting it does at speed. All It should take is to put it under the hood infront of the fender vent. Start recording it with a camera with time stamp, then drive different test of: 20, 30, 40, 50, etc. mph. and log the time and speed. Then compare it to the video and see how much air if any it flows, and what your underhood temps are. Then it would only take a minute to tape over the vents, and go back out and log a base measurement to compare to, or vice versa.
Gunman 07-30-2014 08:42 PM
A camera, and yarn tufts will work too :)
Target70 07-30-2014 09:51 PM
true, that would tell you if you have flow, if not how much of it.
I would like to make a panel with gills, that way the leading edge of each louver would provide a low pressure zone behind it to help suck out the heat.
zkv476 07-30-2014 10:59 PM
I'll get some yarn and a GoPro and figure this out sometime :p. I remember seeing a CFD simulation of the car but someone pointed out that the lines were showing velocity and not pressure areas so it wasn't very useful.
Target70 07-31-2014 01:16 AM
cool thanks.
I figure that even if that area is high pressure, It can't be higher than the pressure in front of the radiator, so even if it isn't drawn out, the heat should get pushed out.
bimmer635csi 07-31-2014 06:19 PM
Flow-vis is useful also. The big guys use it. It is just messy.
http://www.racecar-engineering.com/w.../02/upw03c.jpg
Kuros 07-31-2014 06:44 PM
hmmmm. I may have to try this.
anyone run into any real problems with this?
