Fantastic area under the curve!!
I can't help but wonder with the HP curve being so flat on top that the car would feel like it stopped pulling.. As HP is a function of HP=(TQ x RPM)/5252 in order for HP to stay constant as RPM increases torque would have to drop off quickly. I also noticed you are running more PSI over the RPM band, could this explain the gain in 18whp peak and increased area under the curve? Are these cams intended to spool big turbos early as opposed to top end power? |
Any plans for NA cam packages or testing?
if @FullBlown will i want them to sign me up lol |
As always great results and beautiful parts! Crazy how the whole powerband kicks in sooner.
havent you taken enough of my money =) good job
I will do unspeakable things to swap this motor into an FRS for me and call it my own...feel free to pm for details, lol
Couple of questions:
1; Testing is done using a built long block. Is there any reason why this head package cannot be used on a stock block. 2: Does the increase in lift/duration make the motor an interference motor? (I'm not actually sure if stock fa20 is already an interference motor) 3: Will the sale of this product be offered on a core exhange basis, to minimise down time? 4: Is all varible valve timing and such retained with this package, so that low rpm drivability and economy is minimally effect? Colour me interested by the way. |
Edit: did a quick search if the fa20 was an interferance motor and came up with this thread; http://www.ft86club.com/forums/showthread.php?t=10129 |
There is no reason why you cannot use it on a stock motor. Stock rods are a hit or miss. It would be crappy to have an oem rod let go and destroy everything up top. 2: Does the increase in lift/duration make the motor an interference motor? (I'm not actually sure if stock fa20 is already an interference motor) Stock pistons could have interference issues but we have not yet confirmed this. It will clear every aftermarket pistons out there. (Builder should always check) We advise all customers to let us clearance and shim everything for them. These heads can be tricky to get right. 3: Will the sale of this product be offered on a core exhange basis, to minimise down time? Yes, cores are already in the works. We have been selling this head package without cams for awhile. 4: Is all varible valve timing and such retained with this package, so that low rpm drivability and economy is minimally effect? Yes it is |
Man, y'all are makin' it hard for me not to go nuts on my BRZ. Good work! :)
@FullBlown |
| All times are GMT -4. The time now is 07:27 AM. |
User Alert System provided by
