-   -   Lets talk about clutches (https://www.ft86club.com/forums/showthread.php?t=45589)
Sportsguy83 08-30-2013 11:24 AM
Originally Posted by charged86 (Post 1178436)
I got that trying to see if the frs clutch part number is the same as other Subaru clutch part numbers. hopefully saving us money due to popularity of our platform
FRS/BRZ is part number SU333, Impreza is SU303.
charged86 08-30-2013 11:28 AM
noticed that so frs brz is SU33xx and imprezza is su30xx hmm strike out there but I was getting really excited!
charged86 08-30-2013 11:33 AM
Act part numbers match SB5-HDG6 is same clutch for 06-07 Subaru wrx and the frs
FT-86 SpeedFactory 08-30-2013 11:35 AM
The transmission is different, and most of all the flywheel side is VERY different which everything bolts to.
I do not show the SB5-HDG6 working for the FRS/BRZ.
charged86 08-30-2013 11:36 AM
http://www.ebay.com/itm/ACT-HEAVY-DU...6a0f00&vxp=mtr
http://ft86speedfactory.com/act-6-pu...eight-593.html
its the SB5 is for Subaru wrx and the SB8 is for the frs brz
not trying to insult or pull a fast one on anybody
FT-86 SpeedFactory 08-30-2013 11:37 AM
One is an SB5 and the one for us is an SB8
Plus the one for our cars is cheaper and comes with a flywheel while the WRX is more money and does not come with a flywheel.
Sportsguy83 08-30-2013 11:38 AM
Regardless of part numbers, these are completely different transmissions. Other Subarus do not use Aisin transmissions, are AWD, etc.
For reference, Clutchmasters has a completely new part number for the 86's clutches that is not shared with any other car.
charged86 08-30-2013 11:43 AM
would you recommend the act or the spec for my car?
King Tut 08-30-2013 12:30 PM
I think you are wasting time going down a rabbit hole. Go with a clutch that is meant for the car. While our transmission is similar to the S2000 Aisin box, our engine and flywheel are all Subaru boxer, so it is unlikely any clutch kit not made for the twins will work in our application. You seem set on not utilizing the more popular ACT and Clutchmaster options. I know that SPEC clutches are really popular in higher horsepower cars like Terminators. Personally I think the ACT flywheel/clutch is the best value out there, and with your power, I would definitely get the 6 Puck.
spitfire481 08-30-2013 12:40 PM
i have the spec stage 2+ in my car. installed it last saturday. talk to brady @Pure Automotive . he has done quite a few frs/brz clutches and can get them to you very quick
FT-86 SpeedFactory 08-30-2013 12:45 PM
ACT as it comes with flywheel.
Calum 08-30-2013 02:44 PM
Originally Posted by charged86 (Post 1178310)
lets talk about clutches.
It's sad that the first thing that came to mind was this.
http://stokers.ca/Documents/SSSClutch.zip
Anyway, so far from what I've read the clutch is different. But that was a good question. I know the VW 1.8T and Dodge Neon's pressure plate were identical other then the size of the holes for the dowel pins and the fact that the VW part had a stronger clamp load. I think it was an L drill bit or something to that effect, combined with an old turbo dodge disk and whatever neon flywheel you wanted and you had a very cheap clutch that would happily hold 400 ftlbs.
charged86 08-30-2013 04:13 PM
But I really like rabbits. Anyway yeah I will get the 6 puck act
