-   -   CAMSHAFTS! have they made any? (https://www.ft86club.com/forums/showthread.php?t=43196)
kmbkk 08-02-2013 10:39 AM
That sounds reasonable to me. I'm sure it'll be a PITA to change them, but well worth it.
mid_life_crisis 08-02-2013 11:17 AM
Significant cam change would require stiffer springs, correct?
What effect would stiffer springs have on the variable valve timing mechanism?
industrial 08-02-2013 01:50 PM
Depends on what kind of cam you're running. High lift and high rpm would definitely require springs and retainers. Just higher duration may be ok with stock stuff. But on a boxer you can't just pop a valve cover and swap cams so the way I see it, you might as well do everything you're going to do to the block at once. Which is hard to do when nobody is making parts or experimenting with different setups.
OrbitalEllipses 08-02-2013 01:52 PM
I know people who can do valve adjustments without pulling the block, but yeah most times you're going to pull the block to do any head work.
jamesm 08-02-2013 02:09 PM
i hope they're out by the time my engine comes out for the build (winter time probably). i'm definitely only doing cams if the engine is already out lol.
cf6mech 08-02-2013 02:13 PM
I do believe Ferrea is close to having some available.
Freshfrs86 11-04-2013 06:16 PM
This is what I'm waiting on also. Good advice out there!
No Limit Motorsport 11-04-2013 07:35 PM
I wouldn't be surprised if we saw some debut at SEMA this week.
Adam
