-   -   Hate the feel of the clutch (https://www.ft86club.com/forums/showthread.php?t=41163)
Mikem53 07-10-2013 09:23 AM
Within the first 1k miles of owning this car... I have adjusted the clutch pedal engagement point 3 times.. Was hard to drive smoothly, pedal engaged too high... When I adjusted the pedal to grab at a lower point.. The pedal was physically lowered and the free play at the pedal top was too much. It grabbed lower and initially felt better ... But the whole pedal was now too light with even less resistance.. My 3rd and final adjustment was to put it back to stock..
Now with 2k miles on the odo.. It feels perfect.. As mentioned above.. Give it some time.. It will all come together after the first 1K miles or so..
reeves 07-10-2013 09:26 AM
I love light clutches.. this is the BEST clutch you'll ever experience. Just give it some time. And, of course, make that clutch adjustment referenced above.. it'll make the engagement even better! :thumbsup:
wparsons 07-10-2013 11:12 AM
Originally Posted by radroach (Post 1057307)
I had a tuner shop adjust mine to set at height in line with the gas pedal and also to engage sooner.
If you want a stiffer clutch feel, you could try a lightweight flywheel. I test drove another fr-s with a perrin flywheel and it had a stiffer and abrupt engagement feel.
A flywheel won't change the pedal feel at all, just make it easier to stall it if you're not paying attention.
If the pedal felt different it had a different pressure plate in it.
OICU812 07-10-2013 12:18 PM
Was in same boat now I don't notice at all, adaptation will come.
ramiram1984 07-10-2013 01:24 PM
Buy an aftermarket clutch...etc etc.
