have fun using those on anything but a racetrack. You can't repair CF like aluminum or magnesium. These would be for those with mere money than sense...and show cars (same thing)
In the case of a wheel, the engineers would have started of with certain design requirements, such as a minimum strength and a minimum fatigue life. The wheel would have to be able to withstand the occasional pothole and last through 100,000+ miles of use. So they'd figure out what sort of loads will be placed on the wheels and how many times it will happen. Either with real world testing or a lab experiment, they'd find out how much force the wheel is subjected to when it hits a pothole of a certain size at a certain speed, and they would design the wheel to not bend/break under that force. But since the engineers can never be perfectly sure that every wheel will be made perfectly (most won't be), or that the impact will be exactly as predicted, they need to add in extra strength to make sure that the wheels won't fail and cause someone to be hurt or killed. If a 6061-T6 aluminum (yield stress of 40,000 psi) part was being designed with a safety factor of 2, the maximum stress anywhere on the part during the expected loading scenario should not exceed 20,000psi. 20 x 2 = 40. Safety factors are required in any application, even when weight is crucial. NASA uses safety factors in the range of 1.1-1.05 on satellites and rockets, and that's part of the reason why their stuff costs as much as it does: utterly insane quality control. If Koenigsegg designed the wheels to be durable, they will be. If they sacrificed durability for weight, they won't be. |
1.1-1.05???
Aviation uses a safety factor of 10 minimum building aircraft/parts (hence why whenever fraudulent grade parts are intentionally sold for repairs, consequences can be catastrophic). I would expect NASA to be higher. |
^ Curious how much serious composite engineering went into them. Wouldn't they have been better off using unidirectional fibers designed to resist specific loads? I know that's how racing tubs are designed. Also custom 'homemade' carbon bicycle frames.
Of course I guess it could be a purely cosmetic outer layer because shiny 2x2 carbon = sexiness. Plus is Koenigsegg honestly considered OEM? I though they were really expensive kit cars with Ford power? (ie they made frames, bodies, interiors and maybe suspension links and everything else was off-the-shelf) |
I would be flabbergasted if there hasn't been a great deal of time and expertise put into those wheels. I'm sure there are unidirectional fibers somewhere in the layup, but wheels are also subjected to a great deal of shear force as well, for which 45/-45 cloth is ideal. Quote:
http://en.wikipedia.org/wiki/Safety_factor I read of safety factor when I was studying lifting equipment (particularly ropes, slings, chains, etc). I remember 10 off the top of my head and 5 for things like elevators and cranes. Apparently wiki at the bottom [Choosing Design Factors] has it quoted as 1.2-3.0 depending on materials and structural part. Looking at FAA it seems like those are the tolerances, depending on the part or structure. Perhaps what I learned was bunk, and used for easy examples... who knows. Carry on! |
Looks like they invested their over-priced kit-car profits wisely. What were the problems with the old Dymag (CF rim magnesium center) wheels? Something about de-lamination or breaking from braking heat? How would a whole carbon wheel affect brake temperature in this case since there is less of a heat-sink to suck heat away from the hub? |
These look so good, I think I may make my own damn carbon fiber wheels!
Only with an aluminum core. Sourced from Rota... |
the 360 wheels look wayyyy better.
Also, CF wheels are old news, at least in the Motorcycle world. But hollow, that's pretty cool. Only concern is, CF is known to be very strong, but when it reaches it's failure point...it's known to be catastrophic |
| All times are GMT -4. The time now is 04:21 AM. |
User Alert System provided by
