| mad_sb |
05-19-2013 10:14 AM |
Originally Posted by slowmo
(Post 945107)
Car is running smooth I think the ecu needed time to adapt with the new map
A for learning..... Stock IAM is .7, if the tuner set's it to 1.0 you will get full advance on the first pull ( a few degrees more timing ). Other than IAM, there are the long term fuel trims (these should be reset with each flash or ecu reset). Yes those two things combined could add up to 15whp or more, but from what you describe, it was pulling more and more timing each pull due to learned knock retard so whatever direction your tuner was trying to go was the wrong direction.
It would help if you posted dyno plot and you can send me the data logs if you want an impartial opinion.
(Post 943386)
... first of alk the car ran a base dyno map with an astonishing 169 whp max power...
Was this the map you drove in on or was it the base flash provided by the tuner?
(Post 943386)
..the car did the 1st tune run and I was shocked car dropped 13whp. 2nd run dropped 19whp and it kept going on until the dyno kept reading 145WHP!!!
Were theses multiple pulls on the same tune file, or did he make a pull, change the tune, flash the tune then make another pull?
If they were back to back pulls, you lost power each time either due to learned knock retard or excessive temps or both.
