-   -   Good LED DRLS? (https://www.ft86club.com/forums/showthread.php?t=31579)
OjiGeorge 03-21-2013 10:43 PM
Correct me if I'm wrong, but putting a HID bulb in the DRL/high beam slot would be blinding to oncoming traffic as there is no projector housing there.
Even putting an HID bulb into the stock projectors is a bad idea unless you bend the light cut off metal piece down or get proper projector housings, such as the ones from The Retrofit Source.
jjdrivesajazz 03-22-2013 12:36 PM
80% of the time, you use your high beams to flash for a quick second or use them for a couple seconds on the backroads, rarely do you use your high beams for a long period of time. I do not suggest installing HID kits into the high beam for a couple reasons
-Quick flash of the high beams will cause the bulbs/ballast to fail prematurely
-HID bulbs take about 15-20 seconds to warm up and fully settle in color temperature, so they wouldn't be bright for flashing anyways
-You'd have to run a relay/resistor harness to allow the HID's to function properly during DRL mode
I personally would get a pair of authentic PIAA or Raybrig 9005 bulbs, they work for DRL mode and high beam mode, function like OEM, and are a brighter white than OEM.
husker741 03-22-2013 12:41 PM
Do you have a link to these bulbs?
Kai Uhl 03-23-2013 03:00 AM
Originally Posted by Trashed675 (Post 807014)
Whatever you do DON"T BUY THESE.
I had one separate and fall into the headlight with no way to get it out. I had to bake and split the headlight, i took the opportunity to paint the headlight, but it was still a huge PITA.
I'll post pics if you want, i'm just being lazy.
I bought those exact DRLs lol. I havent had a problem with them though. or at least not yet
Lverasky 04-18-2013 05:01 PM
@jjdrivesajazz is this Cree LED pretty good for DRL or just so so ....
http://www.ebay.com/itm/2pcs-20W-CRE...d5e85a&vxp=mtr
Lverasky 04-18-2013 05:05 PM
http://www.ebay.com/itm/PIAA-Super-P...5b7807&vxp=mtr
Carlitoz3 04-18-2013 06:56 PM
Originally Posted by boredom.is.me (Post 807767)
I second this. It doesn't matter what LED DRL you get. As long as you get an LED DRL, you WILL lose your high beams. I got mine from HID powerhouse and they look good, but I am considering real bulbs.
Why is this?
CamryDS 04-18-2013 07:25 PM
HID_Powerhouse's DRL's are G's 7.5 watt 9005's I have them on my car and they are nice -- I don't care about high beams since i rarely use them. DRL's they are great.
I'm looking for LED low beams now since I really don't care about messing with HIDs anymore.
86 FRS 04-18-2013 08:01 PM
here ya go :)
http://www.ft86club.com/forums/showthread.php?t=27891
FR-Slide 04-18-2013 10:58 PM
Is there no way to hardwire LED DRLs to function as high-beams ever?
Xdragonxb0i 04-18-2013 11:52 PM
They dont just get hot enough/ bright enough to function as High beams.
FR-Slide 04-18-2013 11:54 PM
But I guess what I am asking is, with LED DRLs can you not at least activate them to shine (with low-beams) when the high's are turned on? Surely something is better than nothing, no?
boredom.is.me 04-19-2013 12:44 AM
Originally Posted by Carlitoz3 (Post 875945)
Why is this?
LED's do not project light nearly as well as halogen and HID bulbs.
boredom.is.me 04-19-2013 12:46 AM
They do function when you flip your high beams on. However, they aren't any brighter when in high beam mode than they are when they are on DRL's.
LED -> One Brightness
