@SXE10 Great post, good cut away, and I learned something, order me a cusco filter next! thanks-GREAT stuff
gr8 post OP! |
I can't find the bypass pressure for these filters. Subaru specs a very high bypass pressure (23psi) but most aftermarket filters have bypass valves rated for about half that. I'm not confident that these filters are any different.
Good luck finding any spec like that, the only company I've seen list them is WIX. Their filter for the FA20 is rated at 28psi for the by-pass valve http://www.wixfilters.com/Lookup/Par...spx?Part=57830
The only way I could be persuaded into buying a filter other than OEM is if it had a permanent metal casing with replaceable filter insert. That way you could just change the filter cartridge for a few bucks and produce less waste from metal filters over the life of the vehicle.
Something that looks like this: http://kandpengineering.com/images/S11.jpg http://www.ft86club.com/forums/showthread.php?t=17297 But for the same $150 I'd rather just buy a few cases of OEM filters and recycle them. |
Tokyo Roki Subaru OEM filter or bust.
Does the JDM STI oil filter will be give me more power? :/
i know this is an old thread and all, i was just curious as to how putting a JDM STI filter on a WRX gained 15-25whp... or was it sarcasm?? |
its basically paper in a can, kid......it does not increase displacement nor does it increase air to fuel ratio in your intake manifold.
ohh lol ok no worries then. i was about to be really sad. all good |
You can just pop a normal magnet to any spin off filter for much the same result. |
| All times are GMT -4. The time now is 05:44 AM. |
User Alert System provided by
