-   -   Functional tire combo (https://www.ft86club.com/forums/showthread.php?t=28188)
Tylub 02-05-2013 06:13 PM
Originally Posted by tintumz22 (Post 714120)
What do you mean off by mph in my speedo? I'll be slower than the speedo? So what can you suggest w/o anything being recalibrated?
you'll just be going faster than what the actual speedometer says
just try for tires that maintains the rolling diameter, but in actuality, 2-3 mph isn't going to be much lol
Skurj 02-05-2013 06:17 PM
Your speedometer is also reading fast anyways, that 2-3 mph might actually be making it more accurate, but you can always check your actual speed with a GPS these days and confirm to be safe.
tintumz22 02-05-2013 08:43 PM
Oh yeah. Saw those info about that. I'll check those out in choosing the tires.
Stance86 02-06-2013 05:28 AM
Originally Posted by Tylub (Post 713248)
your offset for the front is pretty aggressive, maybe you'll get understeer
but if you are to be running 9.5 in the rears... you gotta stretch some 235s on there and maybe go 205/215 stretched fronts if you want a tail happy car.
maybe go with a 9.0 rear and 8.0 front to minimalize stretching and still keep the staggered look
I'm not for stretching but if that's what you want :thumbsup:
Don't mean to be rude but unless I am missing something that is terrible advice.. A 205 on the front?? On a 8.5? Why would you do that? And how would that make the car tail happy?
You don't stretch for the sake of stretching, stretch because you run wide wheels and need the room. A 205 would look silly on an 8.5 and is not needed. You could easily run 225 or even a 235 on those wheels without clearance.. On rear you could run a 255 or maybe even a 265 without rubbing. Am I missing something?
tintumz22 02-06-2013 10:59 AM
can you put some insight on the setup I want to attain? I'll appreciate it man!:)
JoeBoxer 02-06-2013 11:05 AM
Why not run the 8.5 +35 all around with a 235/40 or 245/35 tire?
If you do want to run staggered i'd go 225/40 and 255/35 on that size wheel, as long as you don't get something too grippy it should still be ok and if not you can always put a bigger rear sway on it to make it oversteer.
Tylub 02-06-2013 12:12 PM
I know he won't rub if he goes wider, but he already bought his rims and doesn't want the same level of grip as me
