-   Electronics | Audio | NAV | Infotainment (https://www.ft86club.com/forums/forumdisplay.php?f=27)
-   -   Digital speedometer in base GT86? (https://www.ft86club.com/forums/showthread.php?t=20388)
TonyJZX 11-04-2012 09:43 AM
US cluster will be marked in miles per hour... not idea here
you'll want the UK/HK/JP cluster?
encity5 11-04-2012 09:53 AM
you can switch the US cluster to kmph / km if youd like.
russv 11-04-2012 10:59 AM
Originally Posted by Gir (Post 518545)
I like how it doesn't have any tacky silver, and it doesn't have the huge out of place white dial.
The white tachometer dial works because it draws your eyes right to it.
Anduz 11-05-2012 04:40 AM
Originally Posted by @Art_Mighty (Post 537173)
If you paypal the cash I'm willing to ship you a US spec cluster at my cost (dealer retail) i wonder of you just swap in the part, will it work?
how much would a cluster cost from use toyota deals? (scion)
czar07 11-05-2012 06:15 AM
doesnt matter how much the cluster will cost. the question is whether there is wiring for it
Anduz 11-05-2012 06:59 AM
I'm not sure I understand. If there's wiring for the old cluster. Why won't there be wiring for the replacement one?
czar07 11-06-2012 12:44 AM
GT cluster = No digital speed
GTS Cluster = Digital speed read out + other fancy bits
The questions is whether a GTS cluster will plug and play in a GT car?
pezzie 11-06-2012 08:25 AM
Ive been wondering whether this would be a plug and play as well. Maybe a GTS owner and GT owner could test it out? I know the wiring harness plug is the same for the GT, GTS and BRZ cluster, im 100% on that. Im just not sure whether the GT has the appropriate wiring for the digital speedometer to work.
I currently own a 2011 corolla ascent and that car had all the prewiring in place for the fog lights and cruise control, I just bought the parts from the wreckers from an up spec model and it was plug and play. Im hoping this will be the same for the speedometer.
TonyJZX 11-07-2012 09:16 AM
why wouldnt it be the same
i have doubts they'd have a diff wiring loom on gt/gts since its just a minor change
JDMSushi 01-22-2014 08:46 AM
Any updates to this? Is it possible?
PhreshhWun 01-22-2014 04:37 PM
IIRC, swapping the gauge clusters would need to involve some sort of re-programming from the dealers due to the mileage and what not ? So this would be more than a question of is it pNp ?
luv85 01-22-2014 06:18 PM
It is plug and plug but swapping cluster wont work. Few people tried with no luck. apparently you need to swap ECU, cluster, key etc.
Or reprogram the cluster but no dealer will do that for you in australia...
