-   -   Dangerous Catless Smell Driving (https://www.ft86club.com/forums/showthread.php?t=140493)
humfrz 05-22-2020 03:41 PM
Originally Posted by DarkPira7e (Post 3333707)
I'm not sure what it is about the internet where people who don't get the answer they want to hear just keep asking differently, hoping they'll find someone who gives them something they want to hear.
Maybe it's like some women when they are relating a problem - they don't want you to "fix" it, they just want you to listen to them - :iono:
NoHaveMSG 05-22-2020 04:17 PM
http://catalog.remflex.com/SUBARU_He...t_p/16-000.htm
maui86 05-22-2020 04:48 PM
Originally Posted by coconutboy (Post 3333554)
I took this screenshot because Tapatalk wouldn't let me load the video I originally took. Anyways my exhaust system (UEL catless headers, high flow fp & custom catback) is being vacuumed into the car via this bar (right behind the rear bumper) and in turn coming into the cabin while driving with windows down. Anyone know what I should do? Cars naturally have holes to release air but this is not safe to drive in. I blasted the AC, closed all windows and closed my garage door with car off, hovered a cigarette around the bottom of car to see what made smoke move this most, and by far this bar had the most movement. I also put a little trees car fresher in my spare tire well and my whole car smelt like the "Black Ice" scent when I rolled the windows down. Any help is much appreciated. My chest gets tight when driving. This doesnt happen with a stock fp only high flow fp. Thank you!!
There are two vents behind the rear bumper (1 on each side of the car, covered by black flaps) that relive cabin pressure when the doors are closed (take the bumper off, open a door then close the door, you'll see the flaps move.) I suspect this and similar issues may be related to these vents remaining open, possibly in conjunction with any under car exhaust leak either due to a fracture or a bad/leaky gasket.
I recall mention of a TSB being put out by Subaru years ago regarding repair or replacement of these vent flaps to ensure they do not remain open when operating the vehicle.
See if you or your dealer can locate this TSB, and/or install an updated set of flaps and report back on if that fixes this issue.
ls1ac 05-22-2020 07:05 PM
Something does not make sense as newer cars are designed to have positive pressure inside the cabin. Opening the windows will change things as there can be outside air moving around the car depending on speed. But still air should not be coming in through the one way flaps in the back.
NoHaveMSG 05-22-2020 07:17 PM
He has air bags, so very well could be something from the plumbing or wiring install, the compressor is usually in the trunk from what I have seen.
maui86 05-22-2020 07:25 PM
Found the TSB - apparently it was put out due to potential for exhaust to enter the cabin:
https://www.ft86club.com/forums/show...22&postcount=1
coconutboy 06-24-2020 11:37 PM
SOLVED: Air was coming into from the tail lights because I didnt put the OEM gaskets on the Valentis. Never thought to do it. Anyways no problems anymore WAAHOOO
Sent from my SM-G950W using Tapatalk
Daily86 06-28-2020 11:41 AM
Regarding the TSB. It is a Subaru TSB. I have a '17 Toyota 86. Bought it new Aug. '17. I've had this issue from day one. When the A/C is in recirc mode there is fume smell in the car. Complained to dealer, they didn't find anything. So I don't use recirc mode. I've searched online for a TSB from Toyota for this issue and can't find one. I'm past 36k miles now, but I'm going to take the Subaru bulletin to the dealer and see what they say. Don't know when though.
Daily86 08-14-2020 10:12 AM
So I took the car to Toyota and showed them the Subaru TSB. Long story short, the service manager honored the Subaru TSB. Thanks Scott at Treasure Coast Toyota, Stuart, FL.
