-   Suspension | Chassis | Brakes -- Sponsored by 949 Racing (https://www.ft86club.com/forums/forumdisplay.php?f=59)
-   -   Installed coilover; Too much camber in the back. (https://www.ft86club.com/forums/showthread.php?t=12545)
whataboutbob 07-23-2012 10:33 PM
I like the look lowered. Hope you find a good solution to the camber issues.
jamal 07-23-2012 10:35 PM
There are three options
1. raise the car because it's too low
2. get whiteline bushings (you might also need the adjustable toe link)
3. get cusco lower arms (you might still also need the whiteline toe link)
fatoni 07-23-2012 10:40 PM
Originally Posted by project.sth (Post 334247)
Uh? Yeah I think I know all of that. I'm a car mecanic. It mess up the camber and the toe... I was asking if anyone notice the same negative camber reaction to take my choise on ordering parts or lift it up before I'll go to the alignment.
I was hoping for some referance from other people that it's.
Anyway, the FR-S don't have rear camber adjusment ( check the shop manual, it really don't have ) and if someone have already buy the Cusco lower arm I would really know how many degres it can correct.
google camber bolt. i have never heard of a car in history that used a double wishbone and didnt have camber bolts. with the multilink, you should have more adjustability than you do than the fronts
Juanito08 07-23-2012 10:51 PM
How does the car ride on these coils? Please let me know, thinking about getting them
Stav 07-23-2012 10:51 PM
Hi project.sth,
Yes the rear has no factory camber, it is the same as a GRB WRX/STi rear suspension so much so that the Cusco part number is exactlly the same part to fit the GRB/FRS/BRZ to correct your camber issue.
It will easily correct the -2.5 degrees of camber and give you a nicer piece and looks much better especially from the rear.
I am installing the KW V3's this coming Friday as well as the rear camber correction from Cusco or Whiteline.
We are in Mississauga and are the master warehouse for most major suspension companies. We keep the Cusco and Whiteline products in stock in our Mississauga location so that you don't have to deal with the border and all its brokerage and taxes. We ship all over Canada next day UPS so if your ready for it give me a call or pm.
Thank you
Silverdub 07-23-2012 10:56 PM
Originally Posted by Stav (Post 334297)
Hi project.sth,
Thank you
I will add you to my contact list if you dont mind and will soon get parts ftom you im sure for ease over border bullshit and especially for someone having stock and not dropshipping
Stav 07-23-2012 11:01 PM
yes sir, already accepted. The nice part when we ship to PQ there is only GST not QST..... so only 7% tax.
FT-86 SpeedFactory 07-23-2012 11:26 PM
Rear Camber kit...http://ft86speedfactory.com/index.ph...roducts_id=215
Will pull +/- .75 camber. Bring you back to a -1.25 give or take a bit which is much more manageable. You could always raise it up a bit as well. Looks a bit too low. Holler with any questions.
86design 07-24-2012 01:13 AM
could you take a pic from the back ?
whiteline sells camber kit for the rear!!!
trueno86power 07-24-2012 06:44 AM
Hi project.sth,
Thank you
Ahhhh finally answer! I'll pm you.
Really close as stock if you don't put the damper too high. For now I run 15 front and back and it's just a little bit stiffer but that it's.
civicdrivr 07-24-2012 08:23 AM
I'm in the same boat. I got my car aligned though so its only the rear wheels that have crazy camber (-2.3*). $500+ is a bit much IMO for a camber adjustment, and the Whiteline bolts don't adjust enough for my liking.
Sent from my Nexus S using Tapatalk 2
trueno86power 07-24-2012 09:33 AM
Thanks a lot for the result of rear camber. -2.3 don't bother me that much as I will track it. How you lowered as me?
Synack 07-24-2012 09:58 AM
Does anyone know the stock camber for front and rear? I'll likely be lowering mine 1.5" and won't even need a camber adjustment. I like the way it sits with negative camber and I drift so it will need it as well.
Sent from my Galaxy Nexus
Touge Factory 07-24-2012 04:06 PM
Stock camber up front was near 0 degrees, which isn't the best for MacPherson style suspension. We'd recommend adding camber up front for better performance.
Eccentric bolts will be able to assist with dialing out some camber, but will not dial out -2.5 degrees.
Depending on the aggressiveness of the eccentric bolt, you might be able adjust .5 to 2 degrees of camber, however we'd recommend installing adjustable camber arms with high quality bearings.
