If you're unfamiliar with retrofitting: a shop will take apart your headlights and install a different set of projectors, bulbs, lens, etc in to your preference. HIDPlanet and The RetroFit Source are probably the two best places to start. Start there and see if anything piques your interest. Here's a quick review of the Spec-D headlights from a member that has some amazing retrofitting skills: http://www.ft86club.com/forums/showthread.php?t=63406 Also from the same guy, one of the more ambitious projects you can shoot for: http://www.ft86club.com/forums/showthread.php?t=33559 |
Car dismantles or breakers. Avoid the aftermarket tat.
Thanks. I've been trying those with little success. I did find a place in CA that has something that would probably work, but still kinda pricey.
http://www.ft86club.com/forums/showthread.php?t=102373 It's not as awesome as BMW adaptive LED that I have on another car but close and night/day difference with Spyders I had previously which were just crap both in light and build quality. I had to swap the stock ones as I swapped the stock bumper and needed indicators inside the unit. Otherwise, I'd not touch stock lights which were quite good (I had the xenon European spec). |
Just though I would chime in here. I bought a set of Spec D headlights and retrofitted them with stuff from https://www.theretrofitsource.com/.
I went with the MORIMOTO FX-R 3.0 which required me to make custom brackets. But they have other options that literally bolt up no problem. The difficulty is pretty low, wiring them was the most time consuming. Light output and cut off is comparable to a high end luxury car. |
https://www.amazon.com/MOSTPLUS-Sequ...CG40NWHEZZMBV9
Does anybody have any experience with these? Do they come with a harness? I'm assuming they are not plug and play with the MY13-16 BRZ, but could it be done easily? |
Answered my own question, maybe.
[ame]https://www.youtube.com/watch?v=9lTlYfsPQTQ[/ame] |
The fitment isn't perfect either. For $200-250 per headlight they're an upgrade over halogens.no where near OE quality. |
Or worse, they're knock offs which means they're probably worse but who knows. I see no reviews, so you'd be taking a shot in the dark. Worst case the light pattern is crap and you could gut them and put in quality projectors. |
I would recommend that you look into Morimoto headlights if you're looking for a very high-quality option! I have them on my FRS and LOVE them! Pics below!
They are plug-and-play and use only LED bulbs. A 5-year warranty is offered from Morimoto, and the DRL's look amazing IMO! Light output is great as well, didn't need to adjust the headlights at all. -Sam https://scontent-lax3-2.xx.fbcdn.net...6b&oe=5DE1A6A3https://scontent-lax3-2.xx.fbcdn.net...fc&oe=5DA5E723 https://scontent-lax3-2.xx.fbcdn.net...3f&oe=5DA372C5 https://scontent-lax3-2.xx.fbcdn.net...b8&oe=5DA233DD https://scontent-lax3-2.xx.fbcdn.net...a5&oe=5DED4ADD |
@RToyo86 I’ve read this elsewhere, that the projectors are bad. What does that mean? The bulb has defects in the glass, or the concavity is warped or not ideal? Shouldn’t the stock HIDs plug into the projector and work? |
-Sam |
| All times are GMT -4. The time now is 04:45 AM. |
User Alert System provided by
