-   Issues | Warranty | Recalls / TSB (https://www.ft86club.com/forums/forumdisplay.php?f=72)
-   -   Vibrating shifter fix! (https://www.ft86club.com/forums/showthread.php?t=11503)
fistpoint 07-15-2012 05:48 PM
Originally Posted by Draco-REX (Post 316900)
Really? A little bit of engine noise through the shifter is that traumatic for you? Considering the S2000 and Miata both have their shifters attached directly to the transmission as well, they aren't devoid of all vibration. I've driven a Miata and I know for a fact that the shifter is not completely isolated from vibration. Nor did it have appreciably less vibration than the shifter in my BRZ.
So take your troll posts elsewhere.
When you can lose 10lbs of body fat by simply holding the steering wheel in traffic, yes :)
Have you driven a '91 CRX? Oh, I didn't mention the Miata, the other guy did.
Troll? Are you another one of those children that cannot accept other peoples criticism of your purchases? Sounds like it, every car forum has them. I'm waiting for fixes prior to purchase thank you. Does that mean if I do end up buying one that I can no longer criticize my own vehicle? Or are you suggesting only people who own them have a right to criticize?
R8 07-15-2012 06:11 PM
Originally Posted by Draco-REX (Post 316829)
Unlike a lot of FWD cars these days which use cables to link the shifter to the transmission, the shifter in the BRZ/FR-S has a mechanical linkage. Then, on top of that, again unlike FWD cars, the shifter is mounted directly to the transmission rather than the body.
This ^^^^
Our current Civic, as well as my old Eclipse and CRX before that don't/didn't really have vibrations in the shifter. All FWD.
My RX-8 does. Not like OMG what's wrong?!?! vibrations, but you can feel it. RWD.
Hanzo 07-15-2012 07:50 PM
Miata has less vibration, I have had 2 of them. 2006 and 2010.
Bonburner 07-16-2012 12:34 AM
Originally Posted by Kwaziekeller (Post 313082)
I didn't have a vibration, but my shift know was loose (it turned in my hand mid shift one day)... so I tightened it up. a 1/2 turn was about right, but I made the other 1/2 turn so the pattern was right. It's definitely tight! You may be able to get that other 1/2 turn on yours as well.
This happened to me too :/
I really like the stock shifter too
eriktherod 07-16-2012 02:02 AM
I've noticed a little vibration of the shifter, especially at idle. Doesn't bother me really, gives it more of a "race car" feel I guess. The Si didn't have much until I put the stiff motor mounts on it. :D
The one thing I did notice the other day was the way the shifter gives feedback, especially engine braking in lower gears. If you get up to say.. 15 mph or so in first gear and then let off the throttle completely, you WILL feel the shifter move the other direction. It's not like it's going to pop out into N, but I can definitely feel a direct connection to the tranny, which I don't mind really.
cwik 07-16-2012 03:24 AM
Originally Posted by Hanzo (Post 316831)
A good transmission/shifter doesn't have to have vibration for example: Honda S2000, Mazda Miata.
Heh, funny story. As I started university, my brother was just about to start his first full time job. Our cousin piloted us on a joy ride in his 80s Camaro project car. The shifter knob jiggled quite noticeably *all* of the time and after we got out (thanking our lucky stars nothing bad happened while going full throttle on country back roads), my brother commented how the wiggling drove him nuts and he'd never buy a car like that.
Shortly afterwards, he moved away for his job and bought an S2000. Driving it for the first time, I noticed at a stop light how the shifter was vibrating a bit. I commented on it, I think both of us realized that it's not necessarily proof of brute force engineering :P.
In short, the S2000 definitely has a bit of a jiggle.
sho220 07-16-2012 03:29 AM
I've never driven a stick that didn't...
Hanzo 07-16-2012 07:18 AM
My brother had an AP2 S2K and I drove it many times, it was always rock solid in neutral and in gear. Maybe because he bought it brand new, I don't know but I remember driven other S2Ks AP1 and AP2 and they've always felt solid and very little to no vibration from the shifter.
I think the FA engine just has a lot of vibration during higher RPM. I guess that's the nature of that engine. I've had WRX in the past and it is smoother in the higher RPMs.
Draco-REX 07-16-2012 09:50 AM
[quote=fistpoint;316906]When you can lose 10lbs of body fat by simply holding the steering wheel in traffic, yes :)[quote]
Not an issue with the twins. Not sure where you think this is going on.
You quoted his post about the S2K and Miata, agreeing with him.
Troll?
Yes:
It seems today this place is full of buyers/owners who are grasping for straws with excuses to pass off the issues they don't like.
Making a provocative post attacking other members in the hope of getting a rise is trolling.
And it continues:
You haven't been paying attention if you think I'm an apologist.
Another troll attack, and a pretty obvious one too. At no point in my post did I even mention your ownership or lack thereof of a BRZ or FR-S. I didn't bring that up at all, and you are throwing it into the conversation trying to start an argument. If you are just looking to start conflict, again, I recommend you take it elsewhere.
But since you brought it up.. It does make one wonder how you can guage whther someone is compensating for an issue or even if an issue actually exists since you have no basis for comparison with this argument. Instead, you apparently stepped into an argument that you have no familiarity with, with the express purpose of creating drama.
My BRZ has so little vibration it's barely even notable. Granted, my comparison is to the NA Miata. But I can't see a tranmission-mounted shifter having less vibration without it having a lot of slop.
Dunno, I guess I just don't see it as an issue, and feel that going to extremes to eliminate even the mildest of vibration would be wasted effort that would only put a buffer between the driver and the car.
Again, maybe we're talking about different vibrations. I'm talking about the feel through the shifter as I'm driving.
DookDookDGM 07-17-2012 07:17 PM
Waaah vibration, waaaah noises, go drive an AE86, noisiest/most uncomfortable car in the world and still a blast to drive. I like it when my gear lever vibrates, it lets me know that the engine is still fucking running and it's another way to feel the car. seems like a win/win to me.
Hanzo 07-17-2012 10:54 PM
My ae86 didn't vibrate what have you done to it?
denkigrve 07-17-2012 11:06 PM
Welcome to the land of the boxer motor. Horizontally opposed pistons cause vibration in the shifter. If you're hearing noise, something is loose, figure out what and fix it. Mine isn't doing that.
Mr. Mcoupe 07-17-2012 11:14 PM
If they can direct some of the vibration to the passenger seat so that it effectively acts as a g-spot modulator at varying speeds, my gf would love it.
Hanzo 07-18-2012 07:28 AM
You should get the "say the craziest things" award on FT86club.
