I've been on V2.06 Stg 2 EL 93 oct map for less than a week with about 30 miles, and was on the V2.01 map version for about 3-4 weeks prior. V2.01 had less throttle lag and "felt" like it produced a bit more power through 3.5 - 5K rpms, than V2.06. With the current map the lag is significant up to 3.5 - 3.7K rpms, and while power generation is smooth thereafter, it "seems" to build a bit slower than when I had V2.01 loaded.
Previously I ran V1.59 Stage 2 EL E85 and that tune rocked! But, I decided to move back to 93 oct for the winter and convenience since only one station by me carries E85. If it helps work through this, I have a 2013 BRZ with a K&N drop-in (no other intake mods than removing and capping the sound tube) a catless EL header, and a Nameless catback (for sound and looks). Disclosure: I've been lazy and have not captured any logs. If I need to do that for the sake of the community, I'll get off my duff and bone up on the process. I will also comment that discussion seems to be all over the map regarding whether / if / how long the ECU needs to calibrate a new map. For those of us that only have a glimmer of tuning process and architecture it can be confusing. Cheers. |
Hi,
So I recently updated my map from 1.59 to 2.0 at first it was different but now if feels great.. a few hundred kms later.. so I wanted to try out the launch control.. I came to a stop on an empty road and put the gas down, it was holding at around 5800rpm but when I dropped the clutch it bogged right down, no wheel chirp at all, and felt really slow.. is that normal? I had trac control completely off.. and after I did it.. I could smell my clutch.. |
LOL, I hope not, only 14000kms on my car, never tracked and commute to work 100kms a day... Im not even hard on it..
Except when you dump the clutch ;) I kid I kid Sent from my iPhone using Tapatalk |
:lol:Yep mines will be gone soon... But then again I rally my car hahahaha. Break stuff then get better ones!
Well you know... had to try it out :P |
check the mod list in his signiture..... lol |
@ Shiv - Who is that guy after the OFH OFT in your siggie ? Reminds of Juan Epstein from Welcome Back, Kotter :lol:
andy samberg
ok, heres a log with the newest tune, ive never been able to realy log flkc before, so maybe ive always had this and never noticed. but theres over -1.0 flkc at top. maybe my afr is too lean? or is this small enough to not worry about. everything else seems perfect.
http://datazap.me/u/troek/v206-pull-...-4-5-6-7-10-12 |
| All times are GMT -4. The time now is 09:30 AM. |
User Alert System provided by
