Ron |
It's a simple plug and play. The wiring plug is in the lining a few inches to the right of the interior light. You need two OEM parts and a star screw driver. Rear view auto dimming mirror Subaru Part H501SVA200. Mirror mount adapter: H501SSA041 Mirror comes with all parts you need including an adapter to plug it into the existing harness plug in the liner. Install is simple: 1. Remove the old mirror (Turn to left and pull down 2. Pull the interior light assembly down, as if you were replacing the light bulb. 3. Locate the harness plug a few inches to the right of hole you just created. 4. Add the adapter plate to the existing mirror mount. (Two little bolts). I used some thread-lock on the bolts to ensure they do not come loose. 5. Mount and lock the new mirror to the adapter. (a little hex nut). 6. Push the power cable into the headliner where it meets the windshield. There is plenty of flex in the liner to make room for the plug and cable. 7. Connect one end of the cable adapter to the plug in the liner and the other end to the mirror plug you just put into the liner. 8. Push the supplied cable cover into position above the mirror. This hides the cable you just pushed into the liner. 8. Put the interior light cover back into position 9. Turn the mirror on.. DONE. P.S. If you intend to use the compass you will set your GPS zone and drive in circles for about five turns, the instructions are included with the mirror. Took me about 15 minutes and that included me getting tools checking every little detail to ensure I fully understood what was involved. P.S.S When plugging in cable adapter make sure the power is turned off. The power to the mirror is disabled when turned off so you do not need to worry about blowing fuses etc. |
few days ago...Sexy Saturday Shine after car wash & detail by PakShak.
Ron |
Got a suspicion that the dealer over-filled my oil so I came in to have them check it. I heard about how they over-fill it on purpose cause supposedly the car is "known to burn oil". Mine is brand new so it's not burning anything. I looked at both sides of the dip stick, checked on 3 separate occasions now, and all 3 times the oil film is an inch above the mark. Usually one side is right at the dot or slightly above it. But this is way over. Let's see what they say
Update: they changed the filter again "no charge", I guess to smooth things over. I checked the oil level in the parking lot and it was good now. Didn't say anything about the oil level so I suspect it was overfilled. Going to my mechanic from now on, no more dealer |
ft86speedfactory
Latest Upgrade
My latest "upgrade", though I have a K&N air filter coming from Amazon today:
http://www.schweetness.com/sites/def..._dont_care.jpg :fighting0040: |
Didn't want it make a thread for this question so I'll ask here.
Last night when I got home I apparently forgot to lock my doors cause when I was going to work this morning I noticed that the doors were unlocked without me pressing the button on the key. Does the FRS not lock the doors after a certain amount if you forget to lock em yourself? Thanks Sent from my SM-G925W8 using Tapatalk |
First trackday of the year this past weekend. Wife and I had a baby a few months ago, but it was good to finally get out there after about a year off from tracking. Weather was gorgeous too.
https://c1.staticflickr.com/5/4434/3...f48c8eb1_h.jpg |
I know that If you unlock the doors and after 60 secs if the doors don't open ..they automatically lock Sent from my SM-G925W8 using Tapatalk |
If you have one of the special editions that has the keyless setup from the BRZ parts bin, I believe the car will lock itself if your key fob goes out of range. |
| All times are GMT -4. The time now is 08:01 PM. |
User Alert System provided by
